Last Post: BWP 5p
Last Post: Medicalweed
10 Is it important to brush your teeth?
0 Who's still riding???
0 When Were You Born?
Last Post: Henry007
0 Hello everyone!
0 ***DK Custom - Pair of Quality Heim Joints For Harley Shift Linkage***
0 ***DK CUSTOM - Skid Plate for 2004-up Sporty****
0 I've been getting some revenge.
0 Led upgrade 1200S
0 Got New Bike - 2002 Sportster Project
Last Post: mzavala2424
0 primary and gear case cover paint.
0 ***DK Custom-SEE & BE SEEN-LED Front & Rear Lighting***
0 Metal Polishing
0 no introduction needed
Last Post: 60weight
Last Post: SLW210
0 Royal Enfield V-twin concept at EICMA show
0 Chardhin moved to Pennsylvania!
Last Post: lostNdallas
Last Post: paulc
0 Shinko Tyre update - long and boring.
Last Post: slamtry
ironhead, sportster, timing, xlh
Old 10th August 2018
OddRob OddRob is offline
Sportster/Buell Model: XLH 900
Sportster/Buell Year: 1969
OddRob is an unknown quantity at this point
Question 1969 XLH timing
This may have been posted but I could not find it anywhere. I have a 1969 XLH 900 that is running very sketchy no matter how much I mess with tuning the super E carb. I couldn’t find a guide on how to time it to see if it would help anything. It takes a whole lot of kicks to start and using the electric start usually drains the battery after 5 tries. I have replaced and properly gaped the spark plugs. It is running a regulator not a magneto. Does anyone know how I can adjust timing on it at all?? Thanks guys!
doodah man's Avatar
See if this helps you out, and welcome to the forum...
http://xlforum.net/forums/showpost.p...&postcount=111
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
Is the Super E new to the bike ?
Timing doesn't normally change on a bike unless someone "plays" with it.
There are good reasons to check the points gap and the condition of the points and condenser. (Capacitor really).
But if the points gap is close to the FSM figure I would probably not mess with it.
As the linked post says you might want to check that the cam is free to turn and "snaps back" OK.
But I find most of my timing problems are in the carburetor.
Old 11th August 2018
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Your regulator is a timer(distributor). Like said, what are the details? New problem? Old problem with new parts? Or???
Ok, now I'm revived
GA_Ironhead GA_Ironhead is online now
Yes, history of the bike is always useful to diagnose issues.
If you want to do something, you’ll find a way. If you don’t, you’ll find an excuse.
