Last Post: Medicalweed
10 Is it important to brush your teeth?
0 Who's still riding???
0 When Were You Born?
Last Post: Henry007
0 Hello everyone!
0 ***DK Custom - Pair of Quality Heim Joints For Harley Shift Linkage***
0 ***DK CUSTOM - Skid Plate for 2004-up Sporty****
0 I've been getting some revenge.
0 Led upgrade 1200S
0 Got New Bike - 2002 Sportster Project
Last Post: mzavala2424
0 primary and gear case cover paint.
0 ***DK Custom-SEE & BE SEEN-LED Front & Rear Lighting***
0 Metal Polishing
0 no introduction needed
Last Post: 60weight
Last Post: SLW210
0 Royal Enfield V-twin concept at EICMA show
0 Chardhin moved to Pennsylvania!
Last Post: lostNdallas
Last Post: paulc
0 Shinko Tyre update - long and boring.
Last Post: slamtry
Last Post: Four Speed
Old 11th August 2018
chris16371 chris16371 is offline
Sportster/Buell Year: 1991
chris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to behold
Yes stock CV40 carb. I tore down carb and everything looked pretty clean, nothing floating in the float bowl gas and didn't notice anything in the jets. I cleaned everything with canned carb cleaner and blew out all the passages, jets, etc with air. I also checked slide for proper operation. I cleaned the rest of the bike and checked all wiring, connectors, etc and looked good. I let the bike sit for a couple hours until I had to take my fiance to work. Got on and turned fuel on to fill float bowl, pulled enricher and took off and everything worked as it should with no more sputtering on takeoffs. My guess is either something was in a jet or passage that I couldn't see or by following the correct startup/warmup procedure or both. Thanks everyone.
Sent from my SM-G892A using Tapatalk
I only need to use the enricher when the bike won't start without it correct?
Old 12th August 2018
wedge's Avatar
wedge wedge is offline
On a warm day correct. If the bike gets stone cold you will need it.
Have you had the emulsion tubes out to make sure they are clear? It sounds like you fixed the problem, but it sounded like you took a short cut, and sometimes those short cuts end up taking longer.
Yes emulsion tubes have been out. I completely took carb off of bike and took it completely apart and cleaned everything with canned carb cleaner, wire brush, and blew out everything with air. I did this same thing a few weeks ago after installing the new fuel inlet, everything looked pretty clean and no noticeable obstructions anywhere but I proceeded to clean anyways. Anytime I clean carb I take it completely off bike and disassemble completely, I'm sure soaking is a better method than canned cleaner, brush, and air.
wedge's Avatar
I use spray cleaner all the time. As long as you are meticulous as you have been, then it's fine.
Old 13th August 2018
JackFrost71 JackFrost71 is offline
JackFrost71 is on a distinguished roadJackFrost71 is on a distinguished roadJackFrost71 is on a distinguished road
I was told that we will foul the plugs if we use the enrichener like a choke when I bought my bike. If you don't foul them too badly the crud will mostly burn off. That said, if you do forget and foul your plugs a few times too many it's probably a good idea to change them.
Old 19th August 2018
denguy denguy is offline
Sportster/Buell Model: 1200
denguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud of
I just installed a new battery in my 95 1200 and it seems like it starts easier and runs better when cold, especially at low speeds.
Old 20th August 2018
wedge's Avatar
True. That is a good point. A poor battery (or connections) can cause some very strange things and it's easy to overlook.
