Last Post: Medicalweed
10 Is it important to brush your teeth?
0 Who's still riding???
0 When Were You Born?
Last Post: Henry007
0 Hello everyone!
0 ***DK Custom - Pair of Quality Heim Joints For Harley Shift Linkage***
0 ***DK CUSTOM - Skid Plate for 2004-up Sporty****
0 I've been getting some revenge.
0 Led upgrade 1200S
0 Got New Bike - 2002 Sportster Project
Last Post: mzavala2424
0 primary and gear case cover paint.
0 ***DK Custom-SEE & BE SEEN-LED Front & Rear Lighting***
0 Metal Polishing
0 no introduction needed
Last Post: 60weight
Last Post: SLW210
0 Royal Enfield V-twin concept at EICMA show
0 Chardhin moved to Pennsylvania!
Last Post: lostNdallas
Last Post: paulc
0 Shinko Tyre update - long and boring.
Last Post: slamtry
Last Post: Four Speed
Old 8th August 2018
Slick773's Avatar
Slick773 Slick773 is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 97
Slick773 is an unknown quantity at this point
Default Upgrade Rear Rim to 18”
Looking to upgrade rear rim in my 97 Sportster 883. I wanted to put an 18” rear rim, what is the size rim and tire I would need to make this happen without any major modifications?
Old 9th August 2018
wedge's Avatar
wedge wedge is offline
I don't know, but that would be a great mod. You could use grasshoppers and run the bike at speedway.
Old 9th August 2018
Haegar Haegar is offline
Haegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud of
Hi,
I fitted my 2002 XL with 3,5"x18 rear and 2,5"x18 front rims. Tires are 140/70-18 and 100/90-18. This combination fits without any problems. Also has the 140/70-18 tire nearly the same diameter as the 130/90-16. So your speedo is still correct.
Greetings from Germany
Christoph
Old 9th August 2018
hotrodbiker hotrodbiker is offline
Sportster/Buell Model: xl 883/1200
Sportster/Buell Year: 91
Other Motorcycle Model: ducati triumph enfield
hotrodbiker is an unknown quantity at this point
Hi Slick , I m also running 18" rear (and front ) got a 130/90 on the back and 110/80
front , Avon roadriders , added bonus of a good bit of weight loss , those 130s are heavy compared to an 18" !
Old 9th August 2018
cotton1's Avatar
cotton1 cotton1 is offline
Sportster/Buell Model: 1200
Sportster/Buell Model #2: XLH 883
Sportster/Buell Year #2: 1998
cotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond repute
Im in process of trying this on my 1998 883. I bought some parts off CL with the main item being a AMF era 18 inch rim. I mounted a new 4.50 x 18 Shinko Classic 270 on it, when I went to put it on the bike the axle fit perfect, but I need some different spacers to make it work.
The 4.50 is about the same as a 120mm, the stock 16in was running a 130mm so a bit smaller...in the few minuets I had it on there, the rear fender looks way too big. Not a big deal for me since I plan to hardtail and put trailer style rear fender, but something to think about if you are staying stock.
At the moment I am looking for info on it but little time to do so...work,work, work!
Good luck
Cotton1
Old 13th August 2018
Slick773's Avatar
Awesome thanks guys... I’m looking for a new rear rim now!!!
cotton1's Avatar
18 inch? Mag or spoke?
Sent from my XT1254 using Tapatalk
Old 22nd August 2018
cotton1's Avatar
find anything?
Slick773's Avatar
Not yet still looking
