Last Post: BWP 5p
Last Post: Medicalweed
10 Is it important to brush your teeth?
0 Who's still riding???
0 When Were You Born?
Last Post: Henry007
0 Hello everyone!
0 ***DK Custom - Pair of Quality Heim Joints For Harley Shift Linkage***
0 ***DK CUSTOM - Skid Plate for 2004-up Sporty****
0 I've been getting some revenge.
0 Led upgrade 1200S
0 Got New Bike - 2002 Sportster Project
Last Post: mzavala2424
0 primary and gear case cover paint.
0 ***DK Custom-SEE & BE SEEN-LED Front & Rear Lighting***
0 Metal Polishing
0 no introduction needed
Last Post: 60weight
Last Post: SLW210
0 Royal Enfield V-twin concept at EICMA show
0 Chardhin moved to Pennsylvania!
Last Post: lostNdallas
Last Post: paulc
0 Shinko Tyre update - long and boring.
Last Post: slamtry
  #5491
Old 3 Days Ago
newroadster's Avatar
newroadster newroadster is offline
Sportster/Buell Year: 2016
newroadster is a glorious beacon of lightnewroadster is a glorious beacon of lightnewroadster is a glorious beacon of lightnewroadster is a glorious beacon of lightnewroadster is a glorious beacon of lightnewroadster is a glorious beacon of lightnewroadster is a glorious beacon of lightnewroadster is a glorious beacon of lightnewroadster is a glorious beacon of lightnewroadster is a glorious beacon of lightnewroadster is a glorious beacon of light
Removed the tins to finally get them painted. I also I am going to add a smaller tooth front sprocket and a few other upgrades. I removed the rear foot pegs and found my exhaust bracket cracked.
Old 3 Days Ago
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
Originally Posted by JackFrost71 View Post
Have you considered just building a table the same height? $50 or $60 bucks in lumber & hardware should do the trick
I have but a lift would be easier and I can pick up a used one for about $150. Would have had one this weekend if I had a truck to move it with
John Wayne - "The Shootist"
Old 3 Days Ago
Crusty Crusty is offline
Sportster/Buell Model #2: XL1200 R
Sportster/Buell Year #2: 2005
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1979
Originally Posted by dodgetrucken View Post
Had a little problem today when I went to put my 64 back together. I dropped the damn wrist pin clip down into the bottom end. I had to pull my raga to keep that from happening & forget to put them back. Now I have to pull it down.
Try using a telescoping magnet. It will probably pick up the clip and save you a lot of extra work.
Old 2 Days Ago
dodgetrucken dodgetrucken is offline
Sportster/Buell Model: xlh 900 custom
Sportster/Buell Year: 1964
dodgetrucken is just really nicedodgetrucken is just really nicedodgetrucken is just really nicedodgetrucken is just really nicedodgetrucken is just really nicedodgetrucken is just really nicedodgetrucken is just really nicedodgetrucken is just really nicedodgetrucken is just really nicedodgetrucken is just really nicedodgetrucken is just really nice
Yeah that's what a lot of my buddy's have been saying to do. I'm going to pick on up in the next few day. I hope i can fish it out. I do have a crack in the primary side case that needs welded up. The problem with it is that it goes threw a bolt hole... 1 out of 3 isn't to bad lol.
Sent from my SM-N960U using Tapatalk
Old 2 Days Ago
ChinCactus's Avatar
https://www.harborfreight.com/Digita...era-62359.html
Hook, mirror and magnet accessories, video-out cable
These come in handy for a lot of things. Might be worth a try.
Old 2 Days Ago
Wow that would be handy.
Old 2 Days Ago
Subscribing Biker
I've found over the years, you can get all size magnets from old elec. motors. you can even cut or break them to the size you need. I've taped these to mechanics wire, zip ties, fishing line, wrenches, whatever it takes to get in there.
Old 2 Days Ago
Ha, I do have some old speakers out of my old truck around here somewhere. I may try that as well.
Thanks for the ideal.
