Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > GENERAL AREA > Motorcycle Camping
Motorcycle Camping When, What, and When
0 Shuts down after 30 miles
0 where did you put your xlforum patch?
Last Post: tigger
0 Timing issue
0 It's a Buyinhead
Last Post: Tin Man 2
0 Need a source for Ironhead shocks
Last Post: Magneto Sportster
0 Anyone make a DIY vibrating tumbler?
0 Transferring photos
Last Post: bplinson
0 THE Trainspotting Thread
Last Post: Cropduster
Last Post: myrl883
0 Can’t get upper triple tree removed. Advice?
Last Post: Scuba10jdl
0 Re 1986 ignition
Last Post: Edster
0 sommer shootout
Last Post: Racepres
0 900 heads contd..
Last Post: mrmom9r
0 Push Rod Adjustment
0 Laconia Motorcycle Rally 2018
0 Fixing a loose mirror
Last Post: Yochstein
0 Sportster security help
0 ‘68 XLCH...transmission
Last Post: DirtyHarry68
dtremaine (71), Dana (69), Shorty0064 (54), Mini Sumo (50), bikenest (50), ecjq (47), broncobilly (44), XL883L (41), Captain Awesomepants (39), calfunk (37)
  #31
Old 30th July 2012
freeidaho's Avatar
freeidaho freeidaho is offline
freeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to behold
Howdy,
Nice work indeed, and clever use of those tubes.
Tubes for storing welding rod might also work. They have a gasket and seal very well. They usually come in red though.
For the bolt clearance problem, I would get some 1/4-20 "T" nuts for the top. With the right length bolt through from the bottom the top is almost smooth. For the other bolts, I would suggest stainless steel pan head hex head on the top.
I have about the same need as you, but am going to go with a quick detach short sissy bar / rack combo. The sissy bar luggage allows items on both sides of the sissy bar, and can not come off even without tie downs since it slips over the sissy bar. When I'm not taking a trip the bar / rack will come off to leave a clean look.
The Harley versions of sissy bar luggage are sky high for price, but good quality ones at a reasonable cost are available elsewhere on the internet.
But I digress, just stopped by to say nicely done and add a rep for you. Thanks for sharing the story.
Ken Reed
[FONT="Courier New"][SIZE="1"]+-+ freeidaho -at- yahoo -dot- com ........................... There is a $5 fine for whining.
|---\ [url]http://www.parmarng.org/freeidaho/default.html[/url] ......... You are what you do, everything else is just talk.
|----| [url]http://xlforum.net/forums/showthread.php?t=999415[/url] . Eat, sleep, live, love and ride motorcycles.
/-----\ [url]http://www.parmarng.org[/url] ..................... If life throws you a curve, lean into it and apply throttle.
|*------/\ ...............Wouldn't be an economic crisis if you had bought AMERICAN.
|--------| ...............Spent most of my money on cars, motorcycles, guns and girls, the rest I just wasted.
+--------+ ...............Silence is taken as consent. Do you consent? [FONT="Courier New"][/FONT][/SIZE][/FONT]
[IMG]http://www.parmarng.org/freeidaho/MiscHost/IMG_0676-sm.jpg[/IMG]
Old 30th July 2012
Phaedrus's Avatar
Phaedrus Phaedrus is offline
Thanks for the positive feed back and the ideas.
For now I just wrapped hockey tape around the bolts.
They actually keep the gear from sliding off the back.
Those tubes will hold a propane bottle, or a liquor bottle, for emergency situations
Looks great Pete. I think you are going to love the versatility of that setup!
Love the "rocket launchers", Pete, nice idea.
Originally Posted by JohnK View Post
nice job Pete, great idea with the tool tubes
Check your local hardware store for "ELEVATOR" Bolts. They're a male/female combination and will be flat on both sides.. Might be just what you need on that setup..
Now when brad was down for Tiggerstock we measured the bracketry for the saddlebags. Since this is what the Tourpack bolts to, do you think it will also work for a solidmount???
Originally Posted by Billyj7175 View Post
Very slick idea on the fuel tubes...
Do the caps seal as well? (just was thinking that would provide an extra sealing surface in case the fuel bottles themselves leaked).
Originally Posted by freeidaho View Post
Howdy,
Ken Reed
Old 30th July 2012
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Looking good Pete! Well done.
FWIW, I found running button head bolts worked best. But, hockey tape might work too.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 30th July 2012
Teehaml's Avatar
Teehaml Teehaml is offline
Sportster/Buell Model: XL1200C (Traded in)
Other Motorcycle Model: Yamaha FJR1300A
Other Motorcycle Year: 2014
Teehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond repute
Nice job on the rack and great idea with the fuel tubes!
Tom...
Old 30th July 2012
SpartanDen's Avatar
SpartanDen SpartanDen is offline
SpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond repute
I was going to suggest stainless carriage bolts.... but stainless button head cap screws may just as clean.
Denny
Old 30th July 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
Great job Pete! The fuel tubes were a great addition. Hope it gives you the platform that you needed for your trip.
Reps to you!
George
--Thomas Jefferson
Old 3rd October 2012
lfvc77 lfvc77 is offline
Bike Builder
Sportster/Buell Model #2: XL883 SOLD
Other Motorcycle Model: Suzuki Inazuma GW250
lfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant future
I think the will work, but you'd probably have to space out the docking hardware with some washers since the tourpak solo rack is meant for the wider rear fender of the rubbermount.
Old 26th July 2014
jordan1200's Avatar
jordan1200 jordan1200 is offline
Sportster/Buell Model: 883/1200 Hugger Sportser
jordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant future
Love the idea, I have the round tube style rack that I don't think will work. That tour pack rack is for the smaller bullet style turn signals, I wonder if it would work with the larger old style turn signal mounts or if the cut outs for the signals can be enlarged? A bit if a pricey gamble if it didn't fit or modifying it wasn't possible?
Jordan1200
Jordan883
1999 883 Hugger/1200 TS conversion,Buell domed pistons
SE XL bolt-in cams .497's
SE 1200 Ingition Module/7200 rpm.
SE Ignition Coil and wires
SE air cleaner
SE slip-ons
Old 26th July 2014
ReddTigger's Avatar
I Plan on making one fit a solid mount this year.. hopefully..
plan is to cut out a section in the center then reweld it.. should work well enough..
States I've Ridden in
71.3 hp 70.8 tq
Old 26th July 2014
jordan1200's Avatar
Section in the Center? Not following
Jordan1200
