Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > GENERAL AREA > Motorcycle Camping
Motorcycle Camping When, What, and When
0 Rattling noise
0 Rear brake problem.
0 Security system
Last Post: darwin-t
5 Other Bars instead of Buckhorns?
Last Post: KCinSB
0 Indian FTR1200
0 A 5-gallon gas tank?
3 Wtb, Wts, Wtt, Wtg (EFIs)
0 My next trip - AMA Vintage Motorcycle Days in Lexington OH
0 Black Bike Bible
Last Post: grako122
0 Why do sportsters look small?
0 AMF Dealer Accessory Catalog
0 Mid glide
Last Post: farmerbill5
Last Post: gravydog
0 How does it feel?
0 Rubber mount questions.
Last Post: Gazotenekes
0 How many helmets?
0 Mag Wheel Valve Stem Hole
Last Post: RKN
Last Post: Moon Wolf
Last Post: kopbilly1
0 Titanium Retainers
Last Post: Cropduster
10 Greetings from upstate NY
0 carb pop on acceleration from stop
3 Possible ignition module going bad again and throwing timing off...
Last Post: groovemeisterus
NedNimrod, jduffy01, AlanT (70), jzink0883 (69), LVBOATDOC (66), glef (61), Dogsbd (56), darkcustom (41), jon8641 (34)
  #41
Old 26th July 2014
ReddTigger's Avatar
take the tour pak rack and cut it down the middle. then take off the appropriate amount of material then re weld. leaving the ends to connect properly to the smaller width of the frame mount sporty.. vs that of the rubber mount sporty.
States I've Ridden in
71.3 hp 70.8 tq
Old 26th July 2014
jordan1200's Avatar
jordan1200 jordan1200 is offline
Sportster/Buell Model: 883/1200 Hugger Sportser
jordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant future
Oh, didn't realize the rigid is narrower than the rubber mounts. I wonder if I could just have a plate welded to my round tube rack?
Jordan1200
Jordan883
1999 883 Hugger/1200 TS conversion,Buell domed pistons
SE XL bolt-in cams .497's
SE 1200 Ingition Module/7200 rpm.
SE Ignition Coil and wires
SE air cleaner
SE slip-ons
Old 27th July 2014
Have you checked to see if the (front to back) spacing of the mounting studs (both right or both left) are the same between rubber & solid as well??
__o~~o__
IXL2Relax
>>>> Ride Reports Are Here <<<<
Old 27th July 2014
ReddTigger's Avatar
__o~~o__
IXL2Relax
From what I can tell. The distances are the same the width is different. I held up a rigid side plate to a rubbermount and it appeared to match.
Old 27th July 2014
Graywolf Graywolf is offline
Rear rack just fabbed from cold roll. Strong enough to support my weight and probably much more.
I like the diamond plate idea. It would look much better and be lighter.
Graywolf
Old 27th July 2014
jordan1200's Avatar
Nice bike, how did you trike it? Any pics of the actual rack you can post? Was it a complete fab or modification of HD parts?
Jordan1200
Old 27th July 2014
Jordan1200
It is a Frankenstein rear axle kit. Got lots of pictures of the conversion on the Handicapped Rider Forum here.
http://xlforum.net/forums/s....php?t=1792664
Got pictures of the whole trike axle installation, the springer conversion, and the cross over shifter there.
Rear is bobbed off and the rack is bolted directly to the frame. It also supports the tool bags on the sides of the seat. It is kinda heavy, but with a Ford truck axle under it, not a problem with weight.
