0 hello and help!
Last Post: conv90
0 Hello!!!
0 Here goes...
Last Post: 93trident
0 My 1250 to 1275 build
0 Spokes or Mags
Last Post: 51 New West
0 Suggestions on no start
Last Post: Whitewalls
Last Post: thood
0 Speedometer issue
Last Post: Kingrabbit
0 CV carb rubber bung
0 Fitment between 2005 & 2006
0 HAMMERING the Columbia!
Last Post: A Seabee
0 Ulysses Oil Fittings?
Last Post: broknluck
0 5 gal tank
Last Post: Tonyb65
Last Post: Tonyb65
0 Larger gas tank for 1996?
Last Post: Tonyb65
0 is a buell a harley
Last Post: Scott
0 100th Anniversary
accessory circuit, electrical, key switch
Kennyv's Avatar
Kennyv Kennyv is offline
Sportster/Buell Model: xlh-1000
Kennyv is an unknown quantity at this point
I just read this.
Can't stop laughing. I have visions of him trying to fathom how the clutch works.
"I keep twisting the grip but nothing happens."
Sorry Mate, this is all in fun.
No worries, its all cool .. I got a laugh too. For the record though, it was the first thing I thought off. But I looked at the filament and it looked good. usually can see it is broken but my eyes are getting bad with age.
Kennyv's Avatar
Originally Posted by The Doctor71 View Post
Kennyv.... just a heads up. The wiring diagram you're working with doesn't match the factory H-D wiring diagram most of us use. For example, and as previously pointed out by 72 Ironhead, there is no accessory key position in the 1975 model year. And there is no "main circuit breaker" as depicted in your diagram.
Well, that absolutely does explain things and eliminates the confusion. Thank you for posting this Doc.
