0 hello and help!
Last Post: conv90
0 Hello!!!
0 Here goes...
Last Post: 93trident
0 My 1250 to 1275 build
0 Spokes or Mags
Last Post: 51 New West
0 Suggestions on no start
Last Post: Whitewalls
Last Post: thood
0 Speedometer issue
Last Post: Kingrabbit
0 CV carb rubber bung
0 Fitment between 2005 & 2006
0 HAMMERING the Columbia!
Last Post: A Seabee
0 Ulysses Oil Fittings?
Last Post: broknluck
0 5 gal tank
Last Post: Tonyb65
Last Post: Tonyb65
0 Larger gas tank for 1996?
Last Post: Tonyb65
0 is a buell a harley
Last Post: Scott
0 100th Anniversary
  #31
shanneba shanneba is offline
Am I wrong, but is a 5 micron filter going to by-pass more cold oil than a 20-30 micron filter? This is where the 5 micron filter use, confuses me.
Keep in mind that a molecule of motor oil is on the order of a 1000 times smaller than a micron.
A synthetic media 5 micron filter may even flow more oil than a 20-30 micron cellulose filter. (not that Sportsters have a high oil flow, likely less than a gallon per minute even at 7500 rpms)
Even with cold oil, the worst filter in the picture above has only a 5 psi differential pressure at 1 gpm flow rate. Most of the HD Sportster filters that show specs, have about a 10 psi bypass valve, the highest diff. pressure filter would need a flow rate of over 1.5 gpm (about 1.5 times what the Sportster oil pump pumps at 7500 rpms) to get to that level of differential pressure.
At a 2500 rpm fast idle speed the Sportster oil pump would only pump about a quart a minute. At that flow rate none of the filters above would have over 2 psi differential pressure.
With a 20w-50 (would have about twice the viscosity of the 5w-30) oil it might be twice that diff. psi or about 4 psi, still well below the 10 psi bypass setting.
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Sportster/Buell Year: 2018
Tucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura about
Hey everyone. Just giving a Heads Up. Concerning the STP Extended Life filter I'm using. Stopped at the local Auto Zone. Was going to purchase another for the next oil change. Picked up the box. Felt too light. Opened the box. They might have changed the filter?? What I saw had the correct color(Black) and part number. The Anti Drainback Valve was moved further in. Mounting plate was different. The filter looks like a black version of the Cheap Line filter. With the orange(Silicone) Valve. And the case was smaller too. The one Max Life filter I checked looked normal.
Tucsonmax1 2018 Sportster 1200 Custom, 2016 Hyundai Tucson SE AWD
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Originally Posted by Highly-Dangerous View Post
Do you have Whatsapp? pm me your number.
Nope. Don't have that. I've thought about those filters in the past. I'm not convinced they're all that.
HSR42 25 pilot 2 turns Y6 needle jet 97 needle 3rd groove 170 main
