0 hello and help!
Last Post: conv90
0 Hello!!!
0 Here goes...
Last Post: 93trident
0 My 1250 to 1275 build
0 Spokes or Mags
Last Post: 51 New West
0 Suggestions on no start
Last Post: Whitewalls
Last Post: thood
0 Speedometer issue
Last Post: Kingrabbit
0 CV carb rubber bung
0 Fitment between 2005 & 2006
0 HAMMERING the Columbia!
Last Post: A Seabee
0 Ulysses Oil Fittings?
Last Post: broknluck
0 5 gal tank
Last Post: Tonyb65
Last Post: Tonyb65
0 Larger gas tank for 1996?
Last Post: Tonyb65
0 is a buell a harley
Last Post: Scott
0 100th Anniversary
Old 30th June 2019
Bigshankhank Bigshankhank is offline
Sportster/Buell Model: Ironhead Hardtail
Other Motorcycle Model: KTM Duke 390
Bigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant future
Interesting to find this thread, the 1980 hardtail Ironhead I just bought has what appears to be a dirt bike front wheel, thought I cannot tell you from what. Steel rim, which leads me to believe it is off of something older. Eh, time will tell. I’ll have to go count the spokes in the morning.
Old 30th June 2019
73HEAD 73HEAD is offline
Sportster/Buell Year: 1973
73HEAD is an unknown quantity at this point
im running a xl 250 front 21" hub brake wheel. it was on the bike when i bought it and i havent ridden a lot on it. feels quite substantial though and with the 16" rear it sits quite good and does handle well too
Old 30th June 2019
i should count the spokes too. will do so tomoro
Old 1st July 2019
Mines a 40 spoke, steel rim on an aluminum hub. Didn’t look close enough to find any part numbers or info on the hub. Would really like to have a small disc up front just in case.
i just counted mine and its 36 spokes ... 35mm fork tubes. on the right side looking forward , stamped just above axle is 2 D L on the left is 2 D I. no idea. i wish i could work out how to post pictures here.
45Brit 45Brit is offline
Sportster/Buell Model: XL
Other Motorcycle Year: 1975
...lots of British choppers ran the BSA Bantam or Triumph Tiger Cub front hub, back in the 70s and the only real problem was, the brake was effectively useless.
There are some big dirt bikes around, but I take it you are talking about a small drum brake? Why do that? If you want a 21” rim, there are Sportster models which have that. Find one of those, or just build a 21” rim on your existing hub.
Glamazon Glamazon is offline
Senior Master Bike Builder
Sportster/Buell Model: xl883r
Sportster/Buell Year: 2014
Remember that! There was a giant Irishman with red hair down to his ass had a BSA A10 chopper with a Bantam front wheel. He sprayed it Ford purple velvet with gold lace effect, trouble was he used his Mum's best lace doilies! Funniest thing I ever saw was when his Mum found out and laid into him chasing him down the street!
