Last Post: Nitro57xl
0 hello and help!
Last Post: conv90
0 Hello!!!
0 Here goes...
Last Post: 93trident
0 My 1250 to 1275 build
0 Spokes or Mags
Last Post: 51 New West
0 Suggestions on no start
Last Post: Whitewalls
Last Post: thood
0 Speedometer issue
Last Post: Kingrabbit
0 CV carb rubber bung
0 Fitment between 2005 & 2006
0 HAMMERING the Columbia!
Last Post: A Seabee
0 Ulysses Oil Fittings?
Last Post: broknluck
0 5 gal tank
Last Post: Tonyb65
Last Post: Tonyb65
0 Larger gas tank for 1996?
Last Post: Tonyb65
0 is a buell a harley
Last Post: Scott
0 100th Anniversary
  #71
Sirrom1's Avatar
Sirrom1 Sirrom1 is offline
XL Forum Bronze Supporting Vendor
Sportster/Buell Model: 883L
Other Motorcycle Model: Bonneville
Other Motorcycle Year: 1967
Sirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud of
Default Final Gearing Choices
Basically the same for me. 28T with a 150/70-17 rear tire. The math says 20.7 mph per 1,000 rpm in 5th. 83 mph @ 4,000 rpm in 5th. My tach and GPS agrees.
I like my Sportster but if I want to cruise @ 70+ mph (or 100+ mph) I do it on my BMW. It runs fast effortlessly which the Sportster really doesn't.
For those that like the 4000 rpm buzz, great! But if you don't, there are choices, all you need to do is change a pulley or two.
For the 2004-Up Sportster, the rear 68 can be changed to a 66 (2.9%) and the front 28 changed to a 32 (14.3%) for a combined change of 17.2% the 4000 rpm at 80 mph is reduced to 3312. There are choices of 28, 29, 30, 31, & 32 as well as the rear, 66 directly or 61 with a spacer. The rear tire can also be changed, without modification, from 150 to 160. There are choices available. Just decide on what you want, match it to available methods and away you go! Make your Sportster into whatever you want it to be.
...I can't be outta gas,
I haven't turned around yet...
Davo_137's Avatar
Davo_137 Davo_137 is offline
30t front pulley and 66t rear on my XR at the moment .. 75mph is around the 3800rpm area.
Sportster/Buell Model: XLH883
Originally Posted by Ronan978 View Post
Thank you Definitely not my best day , but still very lucky. I had some witnesses also pull over , amazed that I didn’t go down. They said they’d be there if I needed them for anything.
WOW! You must have a good guardian (angel) watching over you! Glad you survived. Hope the insurance company does you right.
Ronan978 Ronan978 is offline
Sportster/Buell Model: xl 1200 custom
Sportster/Buell Year: 09
Ronan978 is just really niceRonan978 is just really niceRonan978 is just really niceRonan978 is just really niceRonan978 is just really niceRonan978 is just really niceRonan978 is just really niceRonan978 is just really niceRonan978 is just really niceRonan978 is just really niceRonan978 is just really nice
That’s exactly what my wife said thank you and me too
