0 hello and help!
Last Post: conv90
0 Hello!!!
0 Here goes...
Last Post: 93trident
0 My 1250 to 1275 build
0 Spokes or Mags
Last Post: 51 New West
0 Suggestions on no start
Last Post: Whitewalls
Last Post: thood
0 Speedometer issue
Last Post: Kingrabbit
0 CV carb rubber bung
0 Fitment between 2005 & 2006
0 HAMMERING the Columbia!
Last Post: A Seabee
0 Ulysses Oil Fittings?
Last Post: broknluck
0 5 gal tank
Last Post: Tonyb65
Last Post: Tonyb65
0 Larger gas tank for 1996?
Last Post: Tonyb65
0 is a buell a harley
Last Post: Scott
0 100th Anniversary
42f67n 42f67n is offline
42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light
Do they fill the same hole that the air goes in?
Momentary Specialist
Sportster/Buell Year: 96
Other Motorcycle Year: 99
Yes, drain and fill through the air hole.
Sleepy Labeef rides again!
rejeanprimeau's Avatar
Why use a rig to empty the shock, I just install them upside down with the air hose sending the oil outward in old water bottles and go for a ride.
b0fh's Avatar
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Year #2: 2017
dyna shocks will not work in a sportster. spring is too heavy because the dynas have the shocks in a higher angle. vrod ones are even worse.
What air pressure do I set the shocks to? For solo and 2 up also what the max air pressure?
I got Genuine Harley Davidson Touring Air Shocks Fits 09-16 Models 54662-09
b0fh's Avatar
35 psi max... usually 0psi solo, 15 2-up
spitfirechopper's Avatar
spitfirechopper spitfirechopper is offline
Sportster/Buell Model: ironhead xlx
Sportster/Buell Year: 1983
Sportster/Buell Year #2: 2005
spitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud of
i run dyna shocks on my sportster, needed some shocks in a pinch and they were cheap.
I can tell you that 0-60mph they are uncomfortably stiff 60-100 they are downright dangerous.
