Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Dirt, Off-Road, and Adventure
Last Post: Nitro57xl
0 hello and help!
Last Post: conv90
0 Hello!!!
0 Here goes...
Last Post: 93trident
0 My 1250 to 1275 build
0 Spokes or Mags
Last Post: 51 New West
0 Suggestions on no start
Last Post: Whitewalls
Last Post: thood
0 Speedometer issue
Last Post: Kingrabbit
0 CV carb rubber bung
0 Fitment between 2005 & 2006
0 HAMMERING the Columbia!
Last Post: A Seabee
0 Ulysses Oil Fittings?
Last Post: broknluck
0 5 gal tank
Last Post: Tonyb65
Last Post: Tonyb65
0 Larger gas tank for 1996?
Last Post: Tonyb65
0 is a buell a harley
Last Post: Scott
0 100th Anniversary
  #51
NLXL's Avatar
NLXL NLXL is offline
Sportster/Buell Model: XL883DLX
Originally Posted by shreksbro View Post
Gotcha. Good idea. Maybe I'll cut the factory one in half and paint it black so it's not noticeable.
Matte black will make it less noticable. When using the factory one you also have the standard (metal) support on it to hold the fork legs together. Not as much as a special fork brace of course, but surely noticable between this one or none at all.
