Last Post: Ghostdog
0 Michigan Thumb Run:
Last Post: Bow only
0 turning idle mixture screw no effect?
Last Post: DéDé
0 Humiliating- I had to push my bike home
Last Post: 11B40
0 My New Daughter "Harley Dee"
Last Post: Bow only
0 Are fly by wire bars different?
Last Post: Wide
0 Kickstands
Last Post: c1skout
0 One more TSM question
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 points/condenser
Last Post: Whitewalls
0 Gauntlet fairing on 99 Sport?
Last Post: c1skout
0 What happened to the Wuhan virus?
0 Mid West Meet & Greet
0 Lets See Your Nightster
Last Post: vaquerodiablo
Last Post: 03SportyBoy
0 Roadster Dampers in Nightster
Last Post: Hornsmith
0 Wiring dual headlight help
Last Post: Sportsnerd
0 883 Highway Speed?
Last Post: Hellbent_4
Last Post: Akdawg
0 A couple more noob questions (Relocating Rear Turn Signals)
0 A couple more noob questions (Fuel, EFI)
0 June 6th, 2020: Ironhead Rider's Gathering, PA/NJ (Spring 2020 G.B.B)
Last Post: Magneto Sportster
cobra47 (73), nardo (61), stevo (56), myrl883 (56), h2ocreeker (54), erreoa (53), abodyjoe (51), MJK (44), bobII (41), motoxxx (35)
  #201
paulc paulc is offline
Sportster/Buell Year: 1976
Sportster/Buell Year #2: 74/5
Starter & solenoid kept on working reliably on the bench, so fitted it all back on the bike today. Put the plugs in to give the starter a decent workload. Pressing the button turns the engine over every time now so problem solved. Seems it was mechanical in nature, soleniod plunger wasn't pulling in far enough to connect large terminals.
All good now so wiring is all done. Next job is make a lid for the electrics box. Then in a couple weeks time I'm taking it to get a 2 into 1 exhaust system made up.
Paul
Sent from my SM-G935U using Tapatalk
you got it.good deal with that.it looked like it moved forward because it couldn't slide freely?
chilly chilly is offline
chilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to all
Well done Paul, onwards and upwards
Yes it seems like it was binding somewhere. Don't think I'll ever know exactly what the issue was but it's fixed now.
Yep, once the pipes are done I'll feel like I'm moving forward a lot.
Paul
