0 Bobtailing a sportster
Last Post: Ted Town
Last Post: rocketnorton
0 springer forks rubbermount 04+
Last Post: Butch 73
6 old dude new here
Last Post: Butch 73
0 🖥️Cyber Monday!🖥️ Big Savings Inside💰Open for Details!
0 first electrical problem
Last Post: denguy
0 Harley super micron 5 oil filter
0 How do I remove the Rear Caliper?
0 The Strociek Project
7 Hi from Spain
0 is a buell a harley
Last Post: Brad
0 Do you run MAXIMUM PSI?!?
Last Post: Tyler45
0 picked up a nail
Last Post: RandallM
0 How Much Money Has Being An XL Forum Member Saved You?
0 Upgrade carb kit
Last Post: halfbreed
0 dyna rear on 05 1200c
Last Post: Butch 73
5 Tire Pressure?
0 Spokes or Mags
0 1979 xlh 1000 wiring problems
Old 29th September 2022
retired retired is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: sportster
Sportster/Buell Year #2: 1977
Other Motorcycle Model: 60 panhead/76 shovelhead
Other Motorcycle Year: 1998
retired has a spectacular aura aboutretired has a spectacular aura aboutretired has a spectacular aura aboutretired has a spectacular aura aboutretired has a spectacular aura aboutretired has a spectacular aura aboutretired has a spectacular aura aboutretired has a spectacular aura aboutretired has a spectacular aura aboutretired has a spectacular aura about
Default distributor
first time in along time on the forum; I had my 69 xlh on the lift table the other because its been running bad. I noticed with bike running that there was a spark at the bottom of the distributor where the bolts and clamp that hold it to the cam cover. It wasn;t sparking all the time but it was arking. I loosened the bolts slightly and it would spark from the bolts to the clamp. Can distributors short out?? Would that affect how the bike idles??
Sportster/Buell Year #2: '03
sounds like a definite short to ground to me inside the ''timer''.H-D's term for your xlh ignition.open up the cover and look for insulated parts that are no longer insulating.
Old 30th September 2022
does that unit use the safety gap in the cap?
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Model #2: 900cc XLB
Sportster/Buell Year #2: 1967
Other Motorcycle Model: 1200cc XLRTT
thefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond repute
The body of the timer is the return path from coil DC plus to earth/battery negative via ignition points...
If timer is ever so slightly loose, the DC plus will spark across to get to earth...
Patrick
the magneto uses the 3/8''safety gap.
Old 1st October 2022
Does the xl use the same timer as a pan?
There is a spring in the bottom that was bad on the one I last fiddled with. It is like a big wavy washer and holds the two halfs of the adjustable timer together.
Old 6th October 2022
Doc308 Doc308 is offline
Other Motorcycle Model: Panhead EL
Other Motorcycle Year: 1948
Doc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to all
The wire to the coil may be shorting against the body of the distributor were it exits. If not,, the unit is easy to disassemble and inspect.
If his distributor is of the older manual advanced type, it would be the same. However, if this bike, a '69, has the model-appropriate automatic
advance type, that spring gadget is not there.
