0 Bobtailing a sportster
Last Post: Ted Town
Last Post: rocketnorton
0 springer forks rubbermount 04+
Last Post: Butch 73
6 old dude new here
Last Post: Butch 73
0 🖥️Cyber Monday!🖥️ Big Savings Inside💰Open for Details!
0 first electrical problem
Last Post: denguy
0 Harley super micron 5 oil filter
0 How do I remove the Rear Caliper?
0 The Strociek Project
7 Hi from Spain
0 is a buell a harley
Last Post: Brad
0 Do you run MAXIMUM PSI?!?
Last Post: Tyler45
0 picked up a nail
Last Post: RandallM
0 How Much Money Has Being An XL Forum Member Saved You?
0 Upgrade carb kit
Last Post: halfbreed
0 dyna rear on 05 1200c
Last Post: Butch 73
5 Tire Pressure?
0 Spokes or Mags
0 1979 xlh 1000 wiring problems
  #171
Old 10th October 2022
PoodlePunche's Avatar
PoodlePunche PoodlePunche is offline
PoodlePunche has much to be proud ofPoodlePunche has much to be proud ofPoodlePunche has much to be proud ofPoodlePunche has much to be proud ofPoodlePunche has much to be proud ofPoodlePunche has much to be proud ofPoodlePunche has much to be proud ofPoodlePunche has much to be proud ofPoodlePunche has much to be proud ofPoodlePunche has much to be proud ofPoodlePunche has much to be proud of
VOES connected
Green lite says "Much VOES, Very Success"
Still need to adjust the timing, but the bike fired right up, no choke, and its in the high 50's here...
on a side note, i now have Tach, and warning lights...
all in all much progress.
wedge's Avatar
wedge wedge is offline
Originally Posted by PoodlePunche View Post
Got my ignition re-wiring wrapped up this weekend...
Used some tech flex, to bundle, and hopefully protect them a bit better this time...
I would grind that down flush inside of the intake to eliminate turbulence, or just pull it out and shorten it until it sits below flush. Loosing some of the other sharp edges in there wouldn't hurt either.
Sportster/Buell Year #2: '03
might give a more accurate signal flush also.
Old 11th October 2022
Ultimately, that is the plan.
I left it as is for now, because i needed to verify it sealed up ok with the white thread sealer...
if i need to add an oring, or something along those lines, the orientation will change, which would be no bueno, if it's already filed down to match the internal angles.
