0 I was at the gym yesterday
0 Koso hd-01-04 2014+
8 Crankshaft Failure
0 Painting fiberglass fender. Paint type?
Last Post: epicjohn
0 wavers
0 Rear wheel alignment
Last Post: v3ko123
0 Need help with turn signal and tail light connections
Last Post: keys79
Last Post: Sasnak75
5 Harley T-Shirts
Last Post: Kbetts
0 HELP Identify These Headers Please
Last Post: FiftySixer
Last Post: Tipofthelake
Last Post: PetesPonies
0 Remember these?
0 Sissy bar with HD quick release bracket
0 Basket case
Last Post: bill smith
0 Cv carb jetting
0 Buell Blast headlight compatibility
Last Post: apotheon
0 Down on oil
Last Post: Billy1200
0 Tappet Block Cover Logo - Recognize?
Last Post: canoli
1911Bronco, Blackbird (82), thai808b (65), Nathan71 (51), lucky-13 (49), Barndog (47), discobanjo (43), albana (41), pat5150 (36)
I wonder if the headlight 'holds power' (internal capacitive battery) for a brief period while the power is cut - such that it may be 'ON LOW' even though it lost power?
Did you check for Diagnostic Codes on the Speedo?
Originally Posted by sml1226 View Post
Low beam never goes out, which is good I guess, but nothing else works. If I shut the bike off after this without killing the lights, it’ll blink out and immediately come back every 5-10 seconds or so.
I'm wondering if the blinking is an 'Error Indication' - Brief loss of power
I highly doubt the loss of power from the regulator/alternator - You could test that theory by simply disconnecting the regulator to battery connection. See if the headlight operates oddly. The bike should run on just the battery without issues...
However, as a precaution (and general preventative maintenance), I would check the battery cables & the grounds:
Also remove the fuses & relays & clean the fuse block - Use dielectric grease on the sockets & reinstall fuses & relays (maybe swap position of relays)...
I returned one of these that started doing this already. Assumed bad light that time, but this one is behaving exactly the same way. Pretty sporadic in when it chooses to not work properly.
Did the replacement headlight work correctly for an extended period of time - and then begin failing? Or did it do this right after installation? Did the first one installed also fail in the same time frame?
Is this the original version headlight or the 'new version'?
That's an expensive device to have two failures in a row... Poor Quality Control?
I’ve lost a couple of charging systems the last 20 years, always seems to be 500 miles from home. I have learned because of this that a fully charged battery, in good condition , and pulling all the fuses except ignition have allowed me to make the return trip home on battery power alone. This small inexpensive voltmeter easily read day or night is my safety net. Not interested in peak output, but impressed by getting full charge at or under 1,500 r.p.m. As opposed to the OEM set up that gets you full charge at 3,500 r.p.m. And it’s entertains watching it dip and rise with different loads. Keep it safe and stay healthy!
Will try this. Http//XLForum.net/forums/attachment...4&d=1596316981
sml1226 sml1226 is offline
Sportster/Buell Model: XL1275R
Certainly possible. No codes though outside of the usual one that the TC88 always throws.
I was thinking it was potentially an error message as well, but you know, they don't give you anything to troubleshoot that. I'll try asking them if that means anything if I can get any help out of JW Speaker.
That would work, but the conditions to make it happen aren't something I've figured out yet. I could have zero issues after disconnecting yet there still be nothing wrong with the charging system. If it did act up, I guess that would tell me it wasn't the charging system, unless I just ran it too low to function...
This was all done when I was having starter issues. Everything there is cleaned, tight, greased, etc after the starter rebuild with no changes to the light, unfortunately.
That I have not done. I think I cleaned a relay, but the rest of that area could stand being looked over.
Original "failure" was the 8690 Adaptive. It lasted a decent stretch of time before any issues ever popped up. The issues cropped up last summer on that one, and by October, I was running through their warranty replacement. I assumed it was overheating or something then, but nothing I did stopped that. The replacement is an 8690 Adaptive 2 as the original was discontinued by then. This one started up fairly shortly after installing it. It was installed shortly before I'd done the starter rebuild if I'm remembering things correctly. The timing of the first one failing is where the suspicion of the regulator comes in. The bike was wrecked in March, and it was pushing summer by the time everything was back together. It didn't act up immediately after that, but like I said, it doesn't do this all that consistently.
And that's why I'm thinking it has to be something beyond the light. My luck is pretty terrible, but I've never seen it be two failed "premium" products bad.
I like the idea, and I may figure out how to integrate one into the bike, but the min/max hold seems like a bit of a necessity for this situation, just so I don't miss whatever oddball behavior is causing this. The output of the 3ph system is certainly nice too, and that is the kind of thing I tend to throw money at without really needing, but I'm still reluctant to jump on that one unnecessarily.
Well, the fuse block looked gross. The actual contact points between the fuse and the socket were nice and shiny, but that was definitely not pretty. Looked like they’d had at least some minor arcing on all of them except the spare, which was just chalky, and the relay, which I’d already cleaned when dealing with the starter (though it looked better than the fuses did when I cleaned it). Cleaned and greased everything, so maybe it’s going to help somewhere. Guess I have to go ride and find out.
And it seems it’s about 10 seconds without power to prompt another full startup sequence. Much less than that and it just pops back on. So if it is caused by losing power, I’d certainly never see it do a full sweep while riding without knowing I had lighting issues.
Thanks for the update - Glad you got the fuses/relays cleaned...
The only other thought I had about diagnosing this is whether you could try it on a friends bike to see if it is the headlight or your bike causing the erratic failure...
If not, maybe you could rig up a short 'Battery to Headlight' harness to setup a a functioning headlight on your bench - Then move the headlight around to see that the headlight 'self-contained' functions work. Since it is so intermittent, it might take a long time testing on the bench (turn it on for awhile - turn it off) before the failure would occur...
Since it is so unpredictable for failure, it's going to be hard to confirm the results of potential fixes...
(Of course, in the end, it just _might_ be another failure of the headlight itself.)
