Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
0 Not an ironhead, but....
Last Post: Peteroo
Last Post: t120r
0 On starting a new thread
0 Cometic Valve Stem Seal Install?
Last Post: BlackBikeDave
0 Will 04 and later used jugs & pistons fit 01 without major problems?
Last Post: tussuck
Last Post: Skeezix
0 5 gal tank
0 Speed
0 1200 conversion
Last Post: Magneto Sportster
0 opinion time (bike broke again)
Last Post: Skeezix
Last Post: r100steve
0 testing wiring harness connections
0 2011 1200C tuner?
Last Post: tussuck
0 Timing
Last Post: ezmerf
0 Mild 1250 build thoughts?
Old 22nd February 2015
Metzman Metzman is offline
Sportster/Buell Model: XB9R
Metzman is an unknown quantity at this point
Question transmission Trap door?
I understand that Harley sportsters previous to 04 had a "trap door" in the case that allowed transmission removal with the engine together. I did a little research and looks like Buell's don't have that trap door feature.
What does the trap door look like (anyone have a picture?) and can it be machined into my cases while I have them apart?
I am a Buell newb and curious. My XB9R needs some tranny work and if the trap door could be added, that would be cool.
Old 23rd February 2015
it would be extremely expensive as it would take cutting, welding and machining. I would guess you would be looking at at least $1,500 to have it done.
Old 24th February 2015
I guess I should start by asking what is the "trap door"?
Does it allow you to pull the trans with the engine cases together?
yes that is correct.
steelworker's Avatar
Other Motorcycle Year: 2016
Tube-frame Buells had the trapdoor, same as the frame-mount Sporties. Fuel-in-frame Buells and rubber-mount Sporties lost the trapdoor.
Does anyone have a picture of what it looks like, the trap door? I have looked at sporty cases online searching using trap door image, but I am not getting it? It looks like the trans on my xb9r should come out without a case split, what is in the way or holds it in so that isn't possible?
Sportster/Buell Year: 1991
This is a custom built one, but you get the idea.
http://www.zippersperformance.com/zi...llet-door.html
John
2007xl1200r's Avatar
2007xl1200r 2007xl1200r is offline
Sportster/Buell Year: 2014
2007xl1200r has a reputation beyond repute2007xl1200r has a reputation beyond repute2007xl1200r has a reputation beyond repute2007xl1200r has a reputation beyond repute2007xl1200r has a reputation beyond repute2007xl1200r has a reputation beyond repute2007xl1200r has a reputation beyond repute2007xl1200r has a reputation beyond repute2007xl1200r has a reputation beyond repute2007xl1200r has a reputation beyond repute2007xl1200r has a reputation beyond repute
I just went to Google and typed "Sportster trapdoor" and found plenty
off images of it. Try trapdoor run together
Bulpitt's Avatar
Bulpitt Bulpitt is offline
Sportster/Buell Model: XLH HAMMER 1250
Bulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud of
Here ya go. This in on my Sporty but its the same thing
Is the trapdoor the trans cover plate? Are the older ones just bigger and that's what allows the trans to come out?
