0 Newbie from Tennessee
0 Harley reliability .
0 Efi and carbs
Last Post: pdavis5160
0 New User, New Parent of an Abused Horse...
0 Long time listened, first time caller
0 45740-62 & 62A differences?
Last Post: 73HEAD
0 Magneto capacitor NAPA cross reference
0 What engine oil do you use?
0 7 Dead and more wounded
Last Post: A Seabee
0 Dual Mikunis
Last Post: solex68
0 head and cylinder painting
0 Got Lights,No Got juice to kill switch,starter button.
0 Throttle Cable For Mikuni
9 Unhappy So Many Electrical Issues
0 Interesting, that's all
Last Post: Scott
Last Post: Bone
0 Stock Seat 48!
0 tire time
Last Post: Madjak
0 Gauge cluster and headlight ID help
Last Post: RoadsterMike
0 Robbie's uncomfortable seat theory
Last Post: robbie202
0 Motorcycle Events
Last Post: rhartlin
0 What Petcock
Old 18th March 2018
jzink0883's Avatar
jzink0883 jzink0883 is offline
Sportster/Buell Model: XL1200CP
Sportster/Buell Year: 2015
Sportster/Buell Model #2: XLH1200 (traded in)
Sportster/Buell Year #2: 1998
jzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond repute
Default Handlebars: stock Iron/48 vs Chumps
Many posts on XLF from Iron/Forty-Eight owners asking how much higher they can go with handlebar rise without needing to replace the brakeline, wiring, or cables.
Net rise to the end of the handlebar:
Stock Iron/48: 3.75"
Biltwell Chumps: 6.00" (top-center bend is higher than the bar end)
Biltwell Frisco: 7.00”
Handlebar width:
Stock Iron/48: 28.5”
Biltwell Chumps: 30.5”
Biltwell Frisco: 28.5”
Per a rider at the Facebook Harley Sportster Touring group, she was able to install 8" Biltwell Chumps (see correction below) on her 2017 Iron 883 with no other changes needed. The brakeline is at its limit, but it works. EDIT (thanks Freud!): The bars on the Iron are actually Bitlwell Friscos. Friscos are 2” narrower and have 1” less rise than Chumps.
The Frisco bars have less rise than the Chumps. However, because the Frisco bars are straight acoss the top, the bar ends are actually higher on the Frisco bars than on the the Chumps.
Bottom Line: To install a taller bar on an Iron 883 or a Forty-Eight using the stock cables and brakeline, Biltwell Frisco handlebars appear to be a better choice than Biltwell Chumps.
Stock Iron/Forty-Eight handlebar specs:
Biltwell 8" Chumps specs:
EDIT: Added Biltwell Frisco specs:
jzink0883, '15 XL1200CP, it ain't butt jewelry, it's a ride
Old 18th March 2018
jzink0883's Avatar
Stock: 3.75"
EDIT Biltwell Frisco: 7.00”
Compared to Chumps and Friscos, H-D Mini-Apes are wider and have more rise. May need longer brakeline, wiring or cables.
H-D Mini-Ape (e.g., Seventy-Two; XL1200CB): 8.75"
H-D Mini-Ape #56079-93 Specs
Old 19th August 2018
Freud's Avatar
Freud Freud is offline
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2014
Freud is a splendid one to beholdFreud is a splendid one to beholdFreud is a splendid one to beholdFreud is a splendid one to beholdFreud is a splendid one to beholdFreud is a splendid one to beholdFreud is a splendid one to beholdFreud is a splendid one to beholdFreud is a splendid one to beholdFreud is a splendid one to beholdFreud is a splendid one to behold
I know it’s an old thread but Im interested and I was wondering what hapened with your bike. The bike shown in the picture is yours? Because those are the friscos if Im not wrong, not the chumps.
Freud's Avatar
I had chumps on a 08’ roadster but it had much wider and taller bars than the iron
jzink0883's Avatar
Freud,
Good eyes! You are correct. The bars in the pictures are Biltwell Friscos. I have added edits to my original post.
I had seen lots of posts on XLF from Iron and Foty-Eight owners asking how much higher they could go with the stock cables and brakeline. The owner of the the Iron shown had posted info about mods on Facebook. The owner told me the taller bars were Chumps and that they fit with the stock cables and brake line.
You are correct. The bars shown in the pic are actually Friscos. Per the Bitwell specs, the Friscos should be an easier swap with the stock cables and brake line. And the end of the Frisco bars is actually 1.0” higher than the end of the Chump bars.
Link to reviews including some fitment comments fro Sportster owners:
- Biltwell Frisco bars: https://www.biltwellinc.com/p43/buy/...uot-black/#diy
- Biltwell Chump bars: https://www.biltwellinc.com/p51/buy/...uot-black/#diy
FWIW. The thread was not about my bike. I have a’15 XL1200CP with factory-installed mini-apes and forwards.
priell3's Avatar
priell3 priell3 is offline
priell3 has a reputation beyond reputepriell3 has a reputation beyond reputepriell3 has a reputation beyond reputepriell3 has a reputation beyond reputepriell3 has a reputation beyond reputepriell3 has a reputation beyond reputepriell3 has a reputation beyond reputepriell3 has a reputation beyond reputepriell3 has a reputation beyond reputepriell3 has a reputation beyond reputepriell3 has a reputation beyond repute
Thanks for this useful post. My son is looking at new bars for his 2017 Iron 883 since he is 6'3". Not having to change the wiring/cabling is a big selling point.
MikeP - 2017 Iron 883
2019 Heritage Classic
Old 20th August 2018
jzink0883's Avatar
For a test fit, your son could get longer riser bolts and a bunch of washers to raise the stock handlebar in the clamp. Stock riser bolts are 1/2-13 X 2-1/2 (Grade 5). Stock washers for the riser bolts are 1/2 X 1-1/8 X 1/8. If necessary, leave the speedo not mounted and secure it with zip ties? Or move the speedo to the eyebrow mounting bolts; there’s a few threads on XLF about moving the speedo mount to the eyebrow bolts.
