Last Post: Adam76
0 '06 Sporster Oil Tank drain
7 Hello from Pennsylvania
0 Dual disks and caliper upgrade
Last Post: doc martin
0 electrical
0 No start no click, helppp plz
6 Hello from Central Vermont
0 Age limit where belts should be replaced?
Last Post: Kbetts
0 Knocking noise in front cylinder!!!!
Last Post: Gespo2
0 Need some help
0 Operation Live Wire
Last Post: Kbetts
0 Old Parts
0 o-ring versus band intakes
0 Nothing much
Last Post: oupa
0 Hello from Germany
5 Harley T-Shirts
0 Forum problems???
0 Piston size id?
Last Post: nychopper
0 Fuel Pump Problems
3 Ironhead Pictures Thread
Last Post: Island Dude
0 1979 XLH Carb
0 Hello from Murcia-SPAIN
stroker ace (79), beunme (59)
Old 21st August 2018
Beelzeboss's Avatar
Beelzeboss Beelzeboss is offline
Beelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant future
Default XL1200S rear shocks - is this stock?
Is this the normal method of attachment for the rear shocks on a Sportster Sport? Or has someone fitted lowering/raising brackets?
Oldrump1 Oldrump1 is offline
Sportster/Buell Model: fxr xl1200 5sp
Sportster/Buell Year: 95
Oldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud of
Yep, lowering brackets, the more the slant from normal lower the bike height.
I don't wanna pickle, just wanna ride my motorsickle
Gene
Beelzeboss's Avatar
Thanks mate! That's awesome news, I'm pretty tall so getting it back to stock height will be much better
jordan1200's Avatar
jordan1200 jordan1200 is offline
Sportster/Buell Model: 883/1200 Hugger Sportser
jordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant future
What year is your bike? Check Ronnie's online microfiche. You should see the have your rear shock part breakdown
Sent from my SM-G930W8 using Tapatalk
Jordan1200
1999 883 Hugger/1200 TS conversion,Buell domed pistons
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
Dynatek DC6-5 Single Fire Coul
SE 1340 air cleaner
Bassani Road Rage 2 into 1 Long Exhaust
