0 Arbor press for crankshaft
Last Post: Maxdog2
0 Hello from San Clemente, California USA
Last Post: Wilkinson949
0 Seized Oil Pump
0 Fuel Pump Problems
0 Rubbermount shocks on a rigid mount?
Last Post: DirtyJay
0 HD Solo Seat and Pillion '86-'03 $130
0 my build in my apartment
Last Post: rickthrash99
0 Finding a new doctor...
Last Post: oupa
0 ***DK Custom-LIMITED TIME Sweetheart Deals-Save 10% On Select Products***
5 What's Your Temp Today
Last Post: Kbetts
10 What's your Personal Tech
0 Motorcycle cafe suggestions
Last Post: oupa
0 compression problems
0 12" or 14"? (Apehangers)
Last Post: oupa
0 Welding on Hardtail
Last Post: Holytown
0 Remove stock kickstand mount from frame
Last Post: Holytown
0 Forum problems???
Last Post: oupa
0 Hello from Belgium
Last Post: old dog
Last Post: Akdawg
beertp (64), Jcolleyoh (64)
Old 15th September 2018
ed_in_az's Avatar
ed_in_az ed_in_az is offline
ed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond repute
First off was the loose front end when I bought it. Tightened up and seemed OK ... for four years.
Though it was not as rock solid as my last full height 883/1200 standard Sporty. While there was no uneasy feeling at high speed it never has returned to straight from a handlebar shake as quickly as my old ride. I've previously chalked this up to less suspension travel and spoke wheels.
Also, if the bearings were damaged from their previous looseness, then the occasional bottoming of these short travel forks couldn't have helped them.
I've got standard firmness Progressive springs in the forks with 5.25" spacers and I'm now inclined to move up to 5.5" just to give them a bit more pre-load. But that's for after the current problem is sorted out.
I was told the tires were balanced. The front was supposed to have been re-mounted, but based on the ribs around it, it's still not perfect. I'll try a spin test of my own. But at 60mph there is zero vibration and perfect straight line tacking.
If new bearings don't fix things I'm thinking about leaving it with the dealer until they sort it out because at that point the ball is clearly in their court.
2008 Nightster 1200 Convertible: Touring/Bobber SE Stage I
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond repute
Post a picture of the tire where you think it doesn't look right.
Ed
The Only Y2K dual-set 883C
So Cal
ed_in_az's Avatar
The pics on my phone.
There are 3 ribs running around the bead. Both after the original install and the dealer's redo there's a bit of variation looking around the rim. They're not uniformly parallel to the rim.
The service Reps seem to think I'm being too picky, but they're not the ones who like to occasionally run down the road at 100mph on my Sportster ... but I do.
Do the ribs on the rear tire look true to the rim?
And the front rim runout, was the runout verified to factory specs? It’s in the book...
Joe
Old 16th September 2018
red sport.'s Avatar
red sport. red sport. is offline
Sportster/Buell Model: sportster XL1200C
Sportster/Buell Model #2: H-D sportster 1200 Custom
Sportster/Buell Year #2: 2010
red sport. has much to be proud ofred sport. has much to be proud ofred sport. has much to be proud ofred sport. has much to be proud ofred sport. has much to be proud ofred sport. has much to be proud ofred sport. has much to be proud ofred sport. has much to be proud ofred sport. has much to be proud ofred sport. has much to be proud ofred sport. has much to be proud of
Default New Tires>Fallaway>Dealer>?
I'm subscribing, I too have a problem after getting new front Tire at my HD Dealer. see what you come up with.
H-D XL1200 sportster custom.
Toejam503's Avatar
Toejam503 Toejam503 is online now
Subscribing Biker
Here is one for the books: There is a local independent shop that I have taken my wheels/tires to that is notorious for mounting the front tires, on Sporty's or any make that has the disc on the left side, the wrong direction. I had to stand and watch, to make sure the tire ran in the right direction. Since most motorcycle tires are directional, this might be something to check because this can cause a lot of vibration with some tires.
Sportster/Buell Year: 1988
Some tyres balance really well. Others require a lot of adjustment. If the tyre had to be reseated was the balance re-checked?
Old 19th September 2018
ed_in_az's Avatar
Update:
I'm taking the bike to HD on Thursday. In preparation, I backed off the bearing tension to 1.5" - 2" fallaway.
At that setting wobbling can be induced anywhere over 50mph. That shouldn't be hard for a test rider to find. Then the can run up the speed until they chicken out and back off. Nobody wants to crash. I sure wouldn't want to hit any bumps with that shaky front end.
Also, I lifted the front wheel and spin tested it. Eyeballing it for wobble it looks like about 1/8" deviation as it spins. I don't know how much it would take to produce the handling problems, but there it is.
What brand of tyre is it?
Very occasionally you get a bad tyre. I had an Avon that was defective many years ago. When I rang the fitters they politely took the P***.
Yet the tyre had strange ridges in the sidewall. They spoke with Avon. Turned out to be a moulding defect. Avon changed it. I politely took
the P*** out of the fitters! More recently the same fitters told me that they think the quality of manufacture is not as consistent as it was
due to out-sourcing.
When you have new tapered bearings the adjustment sets up precisely. If the bearings are worn you get a mushy adjustment - like you describe.
I would change those bearings - because your neck is worth it.
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Model #2: FLHP
Sportster/Buell Year #2: 2016
Other Motorcycle Model: 13 Guzzi V7 / 11 Duc 696
If you've got a local friend the quick and easy way to eliminate or confirm the wheel/tire as a culprit or contributor is to "substitute a known good part".
That is, swap the front wheel/tire from a Sportster riding buddy and go for a test ride. I mean it's pretty dead simple and quick to do and then you'll know.
