0 Trying to figure out if starter or stator
Last Post: andresg3
0 04 883
Last Post: yashko51
0 New Owner
0 Happy Birthday Folkie!!!
0 Donuts in the snow! Best snow video we did this year!
0 Rubbermount Poll
Last Post: Newbeme
0 Home Brewing
0 Brake fluid
Last Post: mwXL 2006
0 Rear Shock length '81
0 Coil suggestions please!!!
0 Sportster Cobra seat
Last Post: USAFpj
0 V Stacks
0 Headlight Modulator
0 Your Favorite Style
0 Pre 04 pistons in later motor?
Last Post: MadMaxUK
Last Post: Maxwell#256
3 Ironhead Pictures Thread
Last Post: Dirt Road Cowboy
Last Post: thecarfarmer
0 Crank position sensor problems ??
Last Post: bobberman66
0 V.o.e.s
0 Windage Tray
Last Post: Blacky
0 Starter Worked, Then It Didn't
Last Post: flthd31
kav2ivan (61), Hunt (54), bikerjim67 (54), twenty2 (42), slimstyle05 (41), PatrickSwayz (35), Mwaggoner
Old 28th May 2019
Thank you very much for the write-up!
I'll add these in the Sportsterpedia.
They look good.
How much time did you spend installing them?
Old 28th May 2019
Rollbar's Avatar
Rollbar Rollbar is offline
Sportster/Buell Year: 1990
Rollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud of
Default 90XLH Hugger Forward Control Help/Install Questions.
Never having done this, it took me about 3-3.5 hours with test fit/ removal then the loctite and reinstall etc.
If I knew what I know now (info in the post), it should only take me about 2hours do the same removal/install on a ‘90 model etc.
Note: the instructions were kind of blurry and I just worked off the last page where it showed what number # bolt when where.
Once I figured that all out it went ok.
Old 28th May 2019
Same here.
I fumbled around with the OEM instructions only to find it was easier to just wing it with the included diagram.
Old 29th May 2019
Got em up Rollbar.
Thank you again.
http://sportsterpedia.com/doku.php/t...forwards_56129
Old 29th May 2019
Rollbar's Avatar
Got em up Rollbar.
Thank you again.
Awesome. Thanks again.
Old 30th May 2019
Bruce's Avatar
Bruce Bruce is offline
Old Fart M/C Club
Sportster/Buell Model: 883/NRHS 1250 custom
Bruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant future
Nice job, they look great. By the looks of those oil lines you might want to change them, look like the are cracking and could start leaking. Ride safe!
Ride safe!
Member of "The Cell #2"
Old 30th May 2019
Rollbar's Avatar
Yes I agree. I should
Have done that. I’ll see if I can find some pretty easy to get a strap wrench and remove the brake arm off the frame support.
Old 15th January 2021
Rollbar's Avatar
I have developed a small leak and I think it is from removing the bottom case bolt to put on the forward controls.
-Never had a leak but my question is, does this bolt have a "O" ring on the ends that I might have missed?
-Could be the center of the case.
-Just a drip every few days, nothing major.
Thanks,
Update: the leak I found is from the sprocket seal.
Old 16th January 2021
rickxx's Avatar
rickxx rickxx is offline
Sportster/Buell Model: 1200c
Sportster/Buell Year: 96
Other Motorcycle Model: harley flhx
Other Motorcycle Year: 07
rickxx will become famous soon enoughrickxx will become famous soon enoughrickxx will become famous soon enoughrickxx will become famous soon enoughrickxx will become famous soon enoughrickxx will become famous soon enoughrickxx will become famous soon enough
Originally Posted by Rollbar View Post
Got them installed.
they look good. nice job.
my '96 1200 Custom
