0 Happy Birthday Folkie!!!
0 Donuts in the snow! Best snow video we did this year!
0 04 883
Last Post: ZCarFan
0 Trying to figure out if starter or stator
Last Post: andresg3
0 New Owner
0 Rubbermount Poll
Last Post: Newbeme
0 Home Brewing
0 Brake fluid
Last Post: mwXL 2006
0 Rear Shock length '81
0 Coil suggestions please!!!
0 Sportster Cobra seat
Last Post: USAFpj
0 V Stacks
0 Headlight Modulator
0 Your Favorite Style
0 Pre 04 pistons in later motor?
Last Post: MadMaxUK
Last Post: Maxwell#256
3 Ironhead Pictures Thread
Last Post: Dirt Road Cowboy
Last Post: thecarfarmer
0 Crank position sensor problems ??
Last Post: bobberman66
0 V.o.e.s
0 Windage Tray
Last Post: Blacky
0 Starter Worked, Then It Didn't
Last Post: flthd31
kav2ivan (61), Hunt (54), bikerjim67 (54), twenty2 (42), slimstyle05 (41), PatrickSwayz (35), Mwaggoner
Old 7th January 2021
Doc308 Doc308 is offline
Sportster/Buell Year: 1969
Other Motorcycle Model: Panhead EL
Other Motorcycle Year: 1948
Doc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to all
The 38mm Mikuni VM -9 's are good starting carbs. They have an enrichener system which works like choke. When you kick with it on, you don't give it any throttle at all. I've run them on a few panheads, a '59 CH, a'77 shivelhead, and my current '69 XLH. All of my bikes have performed great with them installed.
Old 14th January 2021
sungod sungod is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 73
Other Motorcycle Model: sportster
sungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to all
I have 2 Sportsters (70 xlch 73xlh)with vm38 carbs.They are set up identically.The xlch is a 4 kick start(2 kicks key off and 2 key on enrichener on).The 73 xlh enrichener on key on 1 push engine starts.I feel the difference comes down to vaccum created when turning over the engine. Both engines are dialed in and have fresh rebuilds so everything is fairly even.Without an accelerator pump the mikuni requires a strong kick.The carb itself is excellent.Once running the carbs are responsive in all throttle ranges.The issue I have relate to fitment. I wanted to run a turtle tank on the 70 but the top throttle cable interferes with the tank in the stock position. My tillotson fits perfectly.I tried a longer intake manifold but honestly at my age I was killing myself (no need for a gym). Lastly the 70 tach cable rubs the float bowl so it doesn't line up as straight as I would like.
mikethebike61's Avatar
Originally Posted by leon bee View Post
Well, thanks a lot, that's interesting. It doesn't really compute in my mind, but I believe you. New carbs for these bikes, I'm seeing: S&S for $500, Bendix for $400, or Mic for $100.
A NEW S&S for $500? Ones I've seen are closer to $700 with shipping/tax
I have one with the S&S jet kit complete and CLEAN I'll let go for half of new price
Want to lose the Turtle?
Sorry I have tillotsons and a boatail project.
GA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond repute
Kinda off-track, but... I'm seeing prices for the Super E ranging from $350 - 430 (USD), including shipping and tax. Carb only... How many you want at $700, Mike? I take visa/mc/paypal and of course cash. Free shipping to upstate SC.
I don't see where CH is defined here. If it's a mag CH, it may be a bit harder to kick-start than one with battery ignition. Never seen any bad reviews on a VM38-9.
Ham, porkchops and bacon all come from the same magical animal?! That's crazy!
Old 15th January 2021
45Brit 45Brit is offline
Sportster/Buell Model: XL
Other Motorcycle Year: 1975
I fitted a Mikuni conversion to my 1978 XLCH. There is an offset manifold which lowers the carb so it doesn’t foul the underside of the tank, this was a Mikuni part but now very difficult to find. Sudco list them occasionally.
https://www.mikunioz.com/shop/mikuni...v=79cba1185463
Old 18th January 2021
Default mikuni 38mm
That looks interesting.
