0 Happy Birthday Folkie!!!
0 Donuts in the snow! Best snow video we did this year!
0 Rubbermount Poll
Last Post: Newbeme
0 Home Brewing
0 Brake fluid
Last Post: mwXL 2006
0 New Owner
Last Post: Newbeme
0 Rear Shock length '81
0 Coil suggestions please!!!
0 Sportster Cobra seat
Last Post: USAFpj
0 V Stacks
0 Headlight Modulator
0 Your Favorite Style
0 Pre 04 pistons in later motor?
Last Post: MadMaxUK
Last Post: Maxwell#256
3 Ironhead Pictures Thread
Last Post: Dirt Road Cowboy
Last Post: thecarfarmer
0 Crank position sensor problems ??
Last Post: bobberman66
0 V.o.e.s
0 Windage Tray
Last Post: Blacky
0 Starter Worked, Then It Didn't
Last Post: flthd31
Last Post: gravydog
0 This place still sucks!!!
kav2ivan (61), Hunt (54), bikerjim67 (54), twenty2 (42), slimstyle05 (41), PatrickSwayz (35), Mwaggoner
883l, hub, spoke
Old 25th January 2021
Ed.K Ed.K is offline
Sportster/Buell Model: 883L
Sportster/Buell Year: 2012
Ed.K is an unknown quantity at this point
Default 2012 883L mag to 16" spoke wheel
I am thinking to change my 2012 883L mag wheel to 16" front and rear spoke, does anyone know which year model hub is interchangeable without replacing the spacer?
Thanks in advance!
Too bad you're not closer. I have a set of virtually new 16" spoked wheels and tires off my '17 Custom sitting here that I replaced with cast wheels.
When I swapped mine I used: http://sportsterpedia.com/doku.php/t...k:evo:wheels01 and HD parts fiches to figure out which wheels interchanged.
Bluto Bluto is offline
Other Motorcycle Year: 1973
AFAIK all 08+ Sportster wheels take a 25mm axle and rears should interchange no problem, I installed a 2016 rear wheel on my 08. Front fork widths vary so that is something to check spacer wise. Anyway to make sure check out spacers, bearings, etc. at https://partsfinder.onlinemicrofiche....asp?make=hdmc
Old 28th January 2021
Thanks for the information, Is Ronnies open for any customer or only for a distributor? I don't know why they block my IP while I check the part number back and forth now I have to call from Taiwan to ask them to unblock...
It's for customers. I open multiple tabs with one fiche each when comparing and haven't had problems.
+1, have been using Ronnies Parts Finder for 3 years and never had a problem unless their site was down completely. Online US based HD parts vendors won't ship overseas (maybe be some contractual deal with HD ?) so that might be the reason for the IP block. Working currently for me...
+...(maybe be some contractual deal with HD ?)...
Yes, HD has restrictions. It's spelled out on Ronnies' site.
Old 29th January 2021
I tried it again today it works! this time I open multiple tabs no problems show up, many thanks!
