20th November 2019
Posts: 309 Sportster/Buell Model: sportster xlc Sportster/Buell Year: 2005 Sportster/Buell Model #2: xlh 1200 c Sportster/Buell Year #2: 2005 Other Motorcycle Model: Triumph Kawasaki Other Motorcycle Year: 2018
I Dnt know what it revs at so dont know when limiter cuts in,.
What i do know s the Vulcan our accelerates the Harley, so its a long while for Harley to catch it , there's no point in trying HD against my triumph
20th November 2019
Brass Nut
Posts: 46,946 Sportster/Buell Model: XL1200CB Sportster/Buell Year: 2015 Other Motorcycle Model: CRF250L Other Motorcycle Year: 2017
Depends on how they're ridden. Are you hitting the rev limiter in 1st? 2nd? 3rd? (Until you learn not to.)
You should definitely be ahead for, say, at least the first furlong.
Folkie
South East England Riders
20th November 2019
Posts: 2,641 Sportster/Buell Model: xl883n Iron (2019 engine) Sportster/Buell Year: 2017 Sportster/Buell Model #2: xl Hugger (sold) Sportster/Buell Year #2: 2001
Originally Posted by Folkie
That's news to me. AFAIK they're the same. After all, the engines are identical.
ask Kim
Maybe i am wrong
on the lion's corpse celebrate the dogs... still the dogs are dogs and the lion a lion...
20th November 2019
Posts: 3,057 Sportster/Buell Model: 1200/1250C Sportster/Buell Year: 05
Driver error. Maybe switch drivers?
20th November 2019
we did switch bikes on road back the vulcan was still better ,engine pulled very smooth,
harley was very sluggish on acceleration trying to stay with my brother
20th November 2019
Brass Nut
It certainly sounds like an 883. An 883 running on only one cylinder.
20th November 2019
Posts: 1,090 Sportster/Buell Model: XL883DLX Sportster/Buell Year: 1992
https://www.motorcyclespecs.co.za/mo...1200C%2004.htm
https://www.motorcyclespecs.co.za/mo...0s_se%2018.htm
Harley: 58.5 HP, 87Nm, 267kg/589lbs
Kawa : 61 HP, 63Nm, 223kg/491.7lbs
Look at the power/weight ratio...4.6 vs. 3.6
However, the Harley has more torque, so I guess there should hardly be any difference. I think the Harley could outrun the Kawa at the first stretch, then the Kawa will improve due to lower weight and slightly more power.
Maybe it's Hammer time or a simple dyno tune...
Reason: addition
20th November 2019
Posts: 22,249 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006 Sportster/Buell Model #2: XL1200C Sportster/Buell Year #2: 2006 Other Motorcycle Model: 48 "Totalled" By a Douche Other Motorcycle Year: 2012
Seems I ran like 84 mph at the 1/8th mile drags Stage I
The 1250 motor has been over 115 in the 1/4
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
20th November 2019
Momentary Specialist
Posts: 918 Sportster/Buell Model: XL1200 Sportster/Buell Year: 1996 Other Motorcycle Model: ST1100 Other Motorcycle Year: 1999
Originally Posted by NLXL
That’s the lowest rating I’ve seen for 2004-2006 1200, elsewhere I’ve seen 67 Hp for the carbureted bikes and 70 for the newer EFI.
That 58.5 HP rating seems more in line for EVO 1200 with the old heads and D cams.
Even with 67 HP, the Vulcan has an edge in power to weight ratio, but it shouldn’t run away from a good running 2005 1200 Sportster.
As far as top speed, my 1996 with 40k miles will blow by 100mph with ease.
For the OP, if it is indeed a 1200, I’d really be questioning the tune with the add on pipes and air filter.
20th November 2019
@Maxeffort
i really dont know the state of tune boughtit from a dealer mainly Honda,
i dont have any mates who own Harleys to find out things ,thats the reason i joined forum and im definitely getting some help to my daft question,
