0 roadside belt change
Last Post: jazzman
Last Post: commando57
Last Post: Whitewalls
0 Right rear turn signal out 2002 XL1200C
3 Shaky Dave Recovery
0 1970 XLH 900 color?
0 Hi From Atlanta
Last Post: ZCarFan
0 Sleeve cylinders?
0 Options for SE a/c cover
Last Post: tussuck
Last Post: hexnut
Last Post: tussuck
0 TC88A Programming Hardware
0 Ironhead in the uk
0 External breathing systems
0 Sportster Cobra seat
Last Post: duffy
2 My 1275 Hammer Conversion..
Last Post: Firehawk
0 H-D 2019 Financial Results
0 cam lobes
0 The B's Knees...
Last Post: shgrier
0 77 XLCH oil line routing
77xlch, buell_fxr (74), Danny (63), Wino (51), no_chrome (45), USMC_Davii (43), dijitaldna (38), 08nightmare
lowering shocks, rear end, rear shocks, shocks
Old 14th May 2010
JeffXL JeffXL is offline
JeffXL is an unknown quantity at this point
Default Lowering an older ironhead
I am just about finished with the front of my 78.
To date I have:
1) Changed the front wheel to a 21" (laced new rim to my existing hub)
2) Rewired the whole dame bike (8 wires running it total)
3) Bullet headlight, risers and Apes
4) installed 3 degree neck cups (easier than I expected)
5) Shaved and powder coated the forks.
Now I’m working my way back. Being it’s a 78 I don’t want to chop it (hence the neck cups).
What I am looking for is a good solution to lower the back:
I am leaning toward lowering shocks but I can’t seem to find out exactly what will work. I have an 18" rear wheel w/stock struts and fender.
Thought about mounting the fender directly to the swingarm to aviod hitting the tire, but still dont really know how low to go.
Other option is a bolt on hard tail. I don’t love the idea of a bolt on (and would require more parts and work) but it’s not out of the question.
Any advice, options, photos or even a how to would be appreciated
Old 14th May 2010
sddowdy's Avatar
sddowdy sddowdy is offline
Sportster/Buell Model: Sportser
Sportster/Buell Year: 1976
sddowdy is an unknown quantity at this point
If you want to go low, I have seen some guys on here with some pretty low shocks, they must only have about 2" of travel in the shock to be that low. I'm sure someone will chime in on what shocks they use. If not, post this in the 1957-1985 Ironhead section. More Ironhead guys looking at that section than on here, might get a quicker answer. The other option I can think of is a set of struts in place of the shocks. If you go this route I would definitely put a spring seat on there.
You should post some pics of your progress so far, sounds like a cool project.
Old 14th May 2010
Charles: Charles: is offline
Sportster/Buell Model: 1200R Hardtail
Charles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to behold
hard tail!
hard tail!
hard tail!
Old 14th May 2010
crapgame's Avatar
crapgame crapgame is offline
Sportster/Buell Year: 86
crapgame is just really nicecrapgame is just really nicecrapgame is just really nicecrapgame is just really nicecrapgame is just really nicecrapgame is just really nicecrapgame is just really nicecrapgame is just really nicecrapgame is just really nicecrapgame is just really nicecrapgame is just really nice
hi jeff
how do you like the neck cups did you have to lenghen the tubes. got any pics
tom
Old 15th May 2010
Hi CG, I'm pretty happy with the neck cups. Easy to install and they kicked out the front a little without messing up the trail.
I didnt lenghten the fork but I did change the front wheel from 19 to 21".
Ill get come picts up soon.
Old 16th May 2010
SilverShark96's Avatar
SilverShark96 SilverShark96 is offline
SilverShark96 is on a distinguished roadSilverShark96 is on a distinguished roadSilverShark96 is on a distinguished road
I went with a bolt on hardtail on my '78, and I haven't looked back since.
1978 Harley Ironhead - the Italian Rat
Old 18th May 2010
mikes71sporty's Avatar
mikes71sporty mikes71sporty is offline
Sportster/Buell Year: 1971
mikes71sporty has a spectacular aura aboutmikes71sporty has a spectacular aura aboutmikes71sporty has a spectacular aura aboutmikes71sporty has a spectacular aura aboutmikes71sporty has a spectacular aura aboutmikes71sporty has a spectacular aura aboutmikes71sporty has a spectacular aura aboutmikes71sporty has a spectacular aura aboutmikes71sporty has a spectacular aura about
Sure would like to see some pics of your bike with the 3 degree neck cups... Are you using stock forks?
Old 18th May 2010
spdtrux's Avatar
spdtrux spdtrux is offline
Sportster/Buell Model: 79 Ironhead
spdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the rough
Old 18th May 2010
moltenone's Avatar
moltenone moltenone is offline
moltenone is an unknown quantity at this point
hardtail.
Mark
RIDE THE HELL OUT OF IT
expectations are nothing more than predetermined disappointments
Old 18th May 2010
Default Neck cups
here are some picts with the neck cups:
