0 roadside belt change
Last Post: jazzman
Last Post: commando57
Last Post: Whitewalls
0 Right rear turn signal out 2002 XL1200C
3 Shaky Dave Recovery
0 1970 XLH 900 color?
0 Hi From Atlanta
Last Post: ZCarFan
0 Sleeve cylinders?
0 Options for SE a/c cover
Last Post: tussuck
Last Post: hexnut
Last Post: tussuck
0 TC88A Programming Hardware
0 Ironhead in the uk
0 External breathing systems
0 Sportster Cobra seat
Last Post: duffy
2 My 1275 Hammer Conversion..
Last Post: Firehawk
0 H-D 2019 Financial Results
0 cam lobes
0 The B's Knees...
Last Post: shgrier
0 77 XLCH oil line routing
77xlch, buell_fxr (74), Danny (63), Wino (51), no_chrome (45), USMC_Davii (43), dijitaldna (38), 08nightmare
lowered rear shocks, lowering shocks, rear end, shocks
Old 14th May 2010
JeffXL JeffXL is offline
JeffXL is an unknown quantity at this point
Default lowering the back
Looking to lower the rear of my bike. Being it’s a 78 I don’t want to chop it
I am leaning toward lowering shocks but I can’t seem to find out exactly what will work. I have an 18" rear wheel w/stock struts and fender.
Thought about mounting the fender directly to the swingarm to aviod hitting the tire, but still dont really know how low to go.
Other option is a bolt on hard tail. I don’t love the idea of a bolt on (and would require more parts and work) but it’s not out of the question.
Any advice, options, photos or even a how to would be appreciated
Old 14th May 2010
keithb's Avatar
keithb keithb is offline
keithb is an unknown quantity at this point
Can you weigh down the back of the bike to however low you want it to be, and measure for shocks?
Old 14th May 2010
ironhead rider's Avatar
ironhead rider ironhead rider is offline
Sportster/Buell Model: sporster
ironhead rider is an unknown quantity at this point
Progressive 13" did the trick on my 75. They are adjustable, when the wife and i go riding i crank them up two positions and its perfect.
Old 15th May 2010
Fred in WV Fred in WV is offline
Sportster/Buell Model: XLS Roadster
Sportster/Buell Year: 1982
Fred in WV is on a distinguished roadFred in WV is on a distinguished road
You can lower it an inch or so with the bottom bracket adapters sold by most of the suppliers. Easy bolt on install and cheap. If you need more than that you will have to go another route. I put them on my 82 XLS and like the result.
Old 15th May 2010
maritimer's Avatar
maritimer maritimer is offline
Sportster/Buell Model: sportster xlch 900
Sportster/Buell Year: 1969
maritimer is on a distinguished roadmaritimer is on a distinguished road
take off shocks from one of the road king or streetglides
http://www.youtube.com/watch?v=BBNyuf533Go
Old 15th May 2010
The problem with bracket adapters/kits is that I can tfind one made for pre 82.
Do roadking or streetglide shocks work? what do you need to do to make em fit, just switch the bushings?
Old 15th May 2010
dave76's Avatar
dave76 dave76 is offline
Senior Master Bike Builder
Sportster/Buell Model: Sportster XLH 1200
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Sportster XLH 1000
Sportster/Buell Year #2: 1976
dave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to behold
I read some people use 70s FLH stock 12" shocks, these will really lower the bike and may even have some clearence issues. This is what I'm gonna use.
1990 1200 Sportster, Cycle Shack drag pipes, XLC forward controls, Zippers Billet 4 speed trap door.Update, 86 1100 heads, NRHS 1250 cylinders, Andrews V4 cams, and Compufire Elite 1 ignition. 07 Buell oil pump, Complete Andrews 4 Speed gears and shafts, Barnett Scorpion clutch. HHI 3' mid glide trees. HHI 6 piston front caliper, H-D floating rotor.
Old 15th May 2010
oldhippie oldhippie is offline
oldhippie is on a distinguished roadoldhippie is on a distinguished road
went with 11in now problems with top of chain and oil tank
Old 15th May 2010
spdtrux's Avatar
spdtrux spdtrux is offline
Sportster/Buell Model: 79 Ironhead
spdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the roughspdtrux is a jewel in the rough
i have a progressive adjustable load 11.5" eye to eye on my 79 (not sure what model)only issue i ran into was a loose chain.even pulled back all the way.
i just took a link out the chain and its all good. about to throw on 10" rigid struts
Old 15th May 2010
dave76's Avatar
Up to 78 is the old style frame with the midmounted shocks, just an inch or two on our frames goes a long way. The 79 uses the newer triangular frame with rear mounted shocks.
