0 Rear wheel alignment
Last Post: v3ko123
0 Cylinder head interchangeability.. .
0 Does 20W60 reduce cam gear noise?
Last Post: XL Dane
0 Carb Has Me Baffled - Any experienced help appreciated
Last Post: xlh883-1987
0 Run up on the bench
0 Bendix insulator block
Last Post: ronccc
0 Got my Air Shocks, is something wrong?
Last Post: mastiffhound
0 Smoke and top end job
10 big bore question
0 I'm here to learn about my 81 ironhead
0 Oem hd bobtail rear fender 2001 sportster ?
0 Bobtail rear complete assembly for 2001 sportster?
Last Post: FiftySixer
0 Experts Help - Factory OEM Tachometer 2001 883 Custom
0 Transmission figment
0 Stalling when given throttle - video
0 'Floppy' Forks ???
0 Carb not squirting fuel
0 Starter Relay Issues
Last Post: Erikdowney18
5 79 Harley 1000 Roadster Carb
Last Post: farmall
Last Post: bill smith
0 Fun or money?
muddy (68), Ohio48 (64), steelworker (60), Peg Scraper (59), txsurfer (56), eddyw (50), dejomo (42)
Mike1nw Mike1nw is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Suzook Burgman 400/ 2008
Mike1nw is an unknown quantity at this point
Default front wheel bearing advice needed
2007 883
10,300 miles
So there's a really slight "knock" when bike is setting parked, and I turn lock to lock.
I pull front wheel off.
Can't turn bearings with my finger to check for looseness. Maybe they're made that way? Due to being double sealed?
Put front wheel on. Take off caliper. Spins really nice, no looseness. No wiggle.
Put it together. Torque axle and pinch nuts.
Seems OK. Hmmmm.
No looseness or vibes on Highway.
Something is wrong there - You should always be able to spin the internal race of the bearings with your fingers. Perhaps they were assembled wrong last time - Are they the original bearings or replacement ones?
If the outer races are set too deep, there is constant sideways pressure on the inner races because of the hub spacer...
Here's the Sportsterpedia section on wheel bearings:
http://sportsterpedia.com/doku.php/t...k:evo:wheels01
sportsterdoc's Avatar
I had a bearing issue on my 2002 1200S.
Dealer changed tires.
Rear axle did not come out well...so it was driven out, but bearings not replaced.
On the freeway, I heard popping noises and rear hub was hot (70 miles on freeway).
Notice any heat on front hub after a distance?
harley506d's Avatar
Sportster/Buell Model: 1200c
Sounds more like head stock adjustment needed.
xElvis's Avatar
xElvis xElvis is offline
Sportster/Buell Model: XL883
xElvis has disabled reputation
I've blown out 2 or 3 front wheel bearings. Supposed to last 60k I'm told, I got 20k or so a few times. Usually noticed by rust puking out of hub area, and wobbled just a bit when on the axle and in the forks. Can't say I've seen it ever seized. Always a little sloppy when bad, in my limited experience.
xElvis - DOT Certified Cage-Free - '08 883 ~100k miles
I bought this 2007 with 10K on the odometer, I'd assume front wheel bearings are original.
Yes I will check head bearings.
Thanks for sportsterpedia link too!
Might get a new set of bearings and install, just to be sure.
Only 10K miles on bike, but 13 years......
deguireb deguireb is offline
deguireb has disabled reputation
My 05' wheel bearings, both front and rear are difficult to turn with my finger. It can be done but takes effort. They are original and must have been pressed in a little too far. They are smooth and tight so not going to replace them now. It's at 54K miles and not going to change them until the tires are replaced again.... or they go bad. For buying bearing look at Surdyke HD online, they sell them as a pair where dealers sell there individually.
Gold Member's Avatar
Sportster/Buell Year: 1972
Gold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud of
I just changed the front bearings on my ironhead. One side was okay and the other side had rusty brown colored grease in them and were looser than the other side. After as many years as yours is old, I'd suspect simply rain got in it and it's crunchy inside. Cost me $22 to replace them. Headstock bearings are more of course. The bearings wear divots in the races just from vibration. Saw a youtube video where a bike had a detent for going straight iow if you moved the handlebars near straight with bike with wheel off the ground, it would clunk/detent to straight ahead.
Stop by my build thread:
http://xlforum.net/forums/showthread.php?t=2076933
