5 What Color Helmet is Most Noticable?
0 Andrews PB+
Last Post: Nitro57xl
0 Best seat for long rides
5 Vacuum petcock questions...
0 DK Custom 3" Velocity Stack
Last Post: Jcolleyoh
0 Range With EFI 2.1 Gal Tank
Last Post: Dave48
Last Post: conv90
0 Xlch Starter Issue "Need help Diagnosing the problem"
Last Post: USAFpj
0 3.25x19? 90-90x19?
0 story with a moral
0 2005 sporty 1200 belt....
Last Post: 51 New West
0 Need help with S&S GB carb
Last Post: RKN
0 My 1250 to 1275 build
0 69/50 Fest: The 50th Anniversary of the 1969 Sportster (Fall 2019 GBB) 9/14/19
Last Post: 60 XLCH
Last Post: Hornsmith
0 ultima iggy plate near the end of travel
Last Post: cazz1000
0 Have my cake and eat it too? 1275 + 570s + CVJ
Last Post: Traxx
0 sportster chin spoiler, yay or nay?
Last Post: Joe_jeep
0 Opinions - Spring plate REPLACE or REMOVE ???
Last Post: rocketnorton
0 Lets See your bike on a scenic overlook
Last Post: Joe_jeep
0 Tires for "Rubber mount XL" poll.
0 Bar vibration
ziggyhd1 (61), MikeDelta (61), greven (59), bliynd (34)
  #61
Old 14th May 2013
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
Originally Posted by Flame_Retardent View Post
Now you HAVE to finish!! Mwaha!
Darn you Flame!....nuttin' but an instigator!
Originally Posted by Jordan5150 View Post
I think my bike has the HD module, not positive though. My turns used to be run turn stops but one went out when my tire rubbed, and recently the other went out. Still blinks but no run or brake lights.
You might have fried the module....which is why daytonasportster and others suggest the diodes as it will prevent it from doing that.
Cosmo
Old 2nd September 2013
Blow-by Blow-by is offline
Blow-by is a name known to allBlow-by is a name known to allBlow-by is a name known to allBlow-by is a name known to allBlow-by is a name known to allBlow-by is a name known to allBlow-by is a name known to allBlow-by is a name known to allBlow-by is a name known to allBlow-by is a name known to allBlow-by is a name known to all
Is this a mod for those on classics/roadsters/huggers wanting to delete their tail light and have the two turn signals function as brake/run/turn signals?
or would this effectively add running/brake effects to the turn signals if the tail light is left on (which I would be interested in) especially if it could modulate the left and right blinker lights the same way the "back off" lights do.
Old 3rd September 2013
Yes to both....you could either leave it on or remove the fender mounted tail light.
Old 8th December 2013
maurino17's Avatar
maurino17 maurino17 is offline
Sportster/Buell Model: 2005 883R
maurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to all
Hey Cosmo,
Just wanted to let you know as usual a little searching on the XLForum saved me!
I internally wired my bars and absolutely could not get the pins out of the "amp multilock" connectors. I have the manual and read the directions but it was no help. I had to add extra wire anyway so I cut them.
Anyway I didn't want too many solder joints or to reuse the connector so I used your part numbers below for the parts! The dealership had the connectors and pins, and to my surprise I was able to get a service tech to crimp them on to my wire! I still have to connect back to the turn signals but I am going to use basic crimp on connectors for those connections.
Thanks
Greg
Originally Posted by Cosmo Kramer View Post
Don't want to give HD $60 for their module? Don't want to order an aftermarket brake/run/turn module that is made by some 10 yr old girl in China? Now you have another option....do it yourself!
A D.I.Y. brake/run/turn module has come up on the XLF a few times and it was something I wanted to try and understand. I also promised a fellow XLFer that I would design and build a unit and they volunteered as my (New) guinea pig to test the unit long term.
In my design I wanted to keep this as simple as possible but also utilize any existing HD parts. Anyone that has a EFI sporty understands how critical our two relays are in not only allowing the bike to start but also keeping it running. So with that being said I am going to utilize the same relays and also the same relay holder as HD did from 07'-09'.
Alright....here are some of the parts.
Relay:
HD Fuse / Relay Mounting Block - Part #72432-00 - Qty. (1) - Price $3.99 ea.
Relay Terminals - Part # 9937 - Qty. (4) - Price $0.99 ea.
Relay Terminals - Part # 72427-00 - Qty. (4) - Price $0.99 ea.
HD Relays - Part # 31601-04 - Qty. (2) - Price $12.00 ea.
or (and there are others):
NAPA Relay - Part # ECH AR614 - Qty. (2) - Price $7.69 ea.
Connectors:
HD 6-Position Female Connector - Part # 73106-96BK - Qty. (1) - Price $1.49 ea.
HD 6-Position Male Connector - Part # 73156-96BK - Qty. (1) - Price $1.49 ea.
HD Terminals (for female) - Part # 73190-96 - Qty. (6) - Price $0.49 ea.
HD Terminals (for male) - Part # 73191-96 - Qty. (6) - Price $0.49 ea.
Individual Electrical Components:
5 Ohm Resistor - Part # TBD - Qty. (2) - Price $TBD
6A, 50V Diode - Part # 276-1661 - Qty. (4) - Price $2.69
Capacitor - Part # TBD - Qty. (2) - Price $TBD
Old 25th December 2016
Flame__'s Avatar
Flame__ Flame__ is online now
Artist, rider, wrencher
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1988
Other Motorcycle Year: 2000
I never really asked or figured out if this setup cancelled itself if say, the left turn was on and you hit the momentary switch on the right side, or if it was a flash till you hit the button again. I think an arduino setup could be programmed to do that and more. Now that I have this 1989, I remember how frustrating the old turn signals were on my Ironheads. Holding the button to make it flash is just stupid.
Knees in the breeze.
Gamertag, PS4: Bikerdude__
