0 Newbie from Tennessee
0 Harley reliability .
0 Efi and carbs
Last Post: pdavis5160
0 New User, New Parent of an Abused Horse...
0 Long time listened, first time caller
0 45740-62 & 62A differences?
Last Post: 73HEAD
0 Magneto capacitor NAPA cross reference
0 What engine oil do you use?
0 7 Dead and more wounded
Last Post: A Seabee
0 Dual Mikunis
Last Post: solex68
0 head and cylinder painting
0 Got Lights,No Got juice to kill switch,starter button.
0 Throttle Cable For Mikuni
9 Unhappy So Many Electrical Issues
0 Interesting, that's all
Last Post: Scott
Last Post: Bone
0 Stock Seat 48!
0 tire time
Last Post: Madjak
0 Gauge cluster and headlight ID help
Last Post: RoadsterMike
0 Robbie's uncomfortable seat theory
Last Post: robbie202
0 Motorcycle Events
Last Post: rhartlin
0 What Petcock
  #61
Old 20th May 2018
Originally Posted by tarpon4me View Post
I tested all the circuits with a low voltage tester. So the blue and the orange/white has juice all the time when the key is turned on. What could be causing that? I've got to get this thing fixed before he kills himself.
I also could not locate the brake switches for the handle bars or the foot brake. Had no luck with googling or searching for it.
Power on those wires is normal...
You need to look for the Red/Yellow wire...
There was a harness connector under the seat (8-pin) that was then extended back thru the fender to the rear taillight housing where the extension ended in another connector (6-pin) to the taillight circuit board. Both these connectors had a Red/Yellow wire on them which is the Brake Light signal...
The front and/or the rear brake switch should put power onto the Red/Yellow wire in order to light the rear brake light, which should be connected to the 'bright element' in the taillight dual-filament bulb... (the Blue wire should power the 'dim element' in that bulb)
The front brake switch is located inside the right-hand control...
The rear brake switch is a hydraulic switch located on the brake line on the left side of the bike, forward from the rear brake caliper... See item#37 at THIS LINK to the parts fiche...
2 Relax
