0 Torque Cones
0 Jockey Shifter on a Right Side Shift Bike?
Last Post: dodgetrucken
6 1997 Sportster S putting +4 front shocks??
Last Post: Clevspeed
0 Wet sumping?
0 Some oil issues!
0 Gave up and made a bigger fuel tank (see pic)
0 Which cams ?
0 Throttle Cable Adjustment Question
0 Marshwood Vale, 17th June 2019
Last Post: gpydeski
0 Laconia Motorcycle Rally 2019
Last Post: tvon
0 Tools to Lend Out to Forum Members
0 Peak Prices on Our Passion ?
0 XLCH Deluxe option packages
Last Post: AZ66XLCH
0 will not start
Last Post: Airbozo
0 72 XLH1000 Wiring Kit
5 How do you Wash your Bike?
Last Post: Airbozo
10 New to the HD world, Ironhrad vs Shovel, whats the diff
Last Post: kristyza
0 ***DK CUSTOM-Performance Stage I Upgrade Kits for Sportsters-w/Report & Dynos***
0 ***DK Custom - Stealth Adjustable Highway Peg Mounting Kit***
0 DK Custom Speedo Relocation Kits
0 Stator wire hot!
Last Post: Oberlin
0 Leatherlyke bags 2003 vs. later?
breilly888 (67), txsporty (63), michtif (54), Rabs (46)
Old 15th May 2018
jammantoo's Avatar
jammantoo jammantoo is offline
foot in mouth member
Sportster/Buell Model: 48
Sportster/Buell Year: 2016
Other Motorcycle Model: Dou-glide
Other Motorcycle Year: 63
jammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond repute
does anyone make a blinker unit you can swap out for that is designed for LEDs and the Sportster?
Join the PEANUT CLUB, it gives you an excuse to stop and smell the roses
Old 15th May 2018
to get rid of the TSM?
electronic flasher can be used with some wiring. i use one on my 74ch.
Old 15th May 2018
There are plug and play load equalizers availible, I just added one to the ‘04”R” as it now runs with allLED lighting. Functions perfectly. I used the one from”Badlands”.
Old 26th July 2018
Not sure this would work, but just off the top of my head........ I think you could use a solid state flasher unit in connection with the TSM. That would allow you to keep all the functions of the TSM which are desirable, such as the automatic cancelling, etc.
The TSM will flip the lights on even when there is not enough load to flash them, and all the other functions of the TSM such as the hold, the auto cancel, and the manual cancel should still work normally. By wiring the legs of the TSM going to the blinkers on each side to a relay of the proper size that controls something like the Grote 44010 Solid State Electronic Flasher It would flash the blinkers at a steady rate with anything from bare minimum load up to a 12 amp load per side. The TSM is not operating at even enough load to break the blinker circuit so it will never over heat. You could mix LED and incandescent, add more lights, remove lights, switch to different amperage of lights without ever worrying about it.......... so long as you never went over 12 amps per side.
The units are about 4.5 inch X 2.5 inch, so you might need to get a little creative mounting them, but you would eliminate any concerns about swapping lights or overloads.
I am not an electrical engineer and I don't know if that would work or not. If it would not work I would appreciate knowing why. It was just an idea.
PDF - solid state flashers and specs - https://www.grote.com/wp-content/upl...l-Switches.pdf
Custom Dynamics also has a flasher unit that is very small and made for motorcycles.
Graywolf
Old 8th August 2018
you do not need relays, diodes will work, the purpose of the ones on the picture i posted. most any auto parts store will have electronic flashers, just get one that says it will flash down to one bulb. i use one meant for a ford.
Old 15th August 2018
VaFish VaFish is offline
Sportster/Buell Model #2: 883 Blue
Sportster/Buell Year #2: 1997
Other Motorcycle Model: A pile of Ninja 250's
Other Motorcycle Year: 1988
VaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond repute
this is a simple fix with a single circuit, i made two for less than 20 bucks. it does not require soldering or splicing the harness. it will handle the entire system including 4 way function.
will post the circuit later, on road trip and using this small screen is the pits!
http://xlforum.net/forums/showthread.php?t=1863262
On your drawing is the blue line a wire connecting the two resistors together in parallel?
Old 16th August 2018
if you look at the tread led load block, it shows how to build it. but yes, the resistors are tied together on both ends.
https://www.youtube.com/watch?v=RpcgBGPgXzs
