3 So here's the idea... (for a chopper)
Last Post: Holytown
0 Operation Argument aka Big Week
0 Hello from NY
Last Post: XL Ed
0 Do you think is normal this fuel pump noise?
Last Post: hexnut
0 Trackday Sportster
0 THE Trainspotting Thread
0 And so it begins......
Last Post: Rossline
Last Post: Blowupster
0 1965 Ironhead in CT
Last Post: Moon Wolf
0 Mag wheel corrosion
Last Post: Thyratron
0 Mainshaft- What happened here
Last Post: shaymus
0 Forum problems???
Last Post: CMCSSeabee
0 85 clutch adjustment woes
0 Rubbermount shocks on a rigid mount?
6 Is Your SPORTSTER...
Last Post: Magneto Sportster
0 Who's still riding???
0 62 xlch
Last Post: oupa
0 12" or 14"? (Apehangers)
0 Spokes or Mags
Last Post: Desertfox
0 XR1200 belly pan on an XL?
cbsportster (68), sjeccles (51), 2011_Nightster (51), reeb (48), Maff (48), jl_rotary (41), UMLsilva (33)
Old 17th June 2018
jordan1200's Avatar
jordan1200 jordan1200 is offline
Sportster/Buell Model: 883/1200 Hugger Sportser
jordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant future
Default Just did a lower right hand switch housing swap
Just did a lower right hand switch housing swap and my right front turn signal looks like both lights are alternating when the turn signal is on.
Thoughts..
https://drive.google.com/file/d/1Fpt...w?usp=drivesdk
Sent from my SM-G930W8 using Tapatalk
Jordan1200
1999 883 Hugger/1200 TS conversion,Buell domed pistons
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
Dynatek DC6-5 Single Fire Coul
SE 1340 air cleaner
Bassani Road Rage 2 into 1 Long Exhaust
Old 19th June 2018
jordan1200's Avatar
Issue resolved
