Last Post: beeman07
0 ***DK Custom-Improved Front Suspension w/ Intiminator Fork Valves***
Last Post: Jollly Rogers
0 will not start
Last Post: 01rk
0 Jockey Shifter on a Right Side Shift Bike?
Last Post: dodgetrucken
0 Stator wire hot!
0 1991 frame/engine original ground locations
Last Post: Jer
0 Stock air cleaner box modifications
0 .551 Cams in an EFI 1200
Last Post: EL in NH
0 Peak Prices on Our Passion ?
Last Post: slojoe631
0 Wet sumping?
0 Gave up and made a bigger fuel tank (see pic)
Last Post: Hornsmith
10 New to the HD world, Ironhrad vs Shovel, whats the diff
Last Post: A Seabee
0 72 XLH1000 Wiring Kit
Last Post: A Seabee
0 Some oil issues!
5 How do you Wash your Bike?
Last Post: xElvis
0 Mystery drip off rear brake cylinder
0 Calling all "Long Frame" riders...
Last Post: Whitewalls
0 sproket issues
Last Post: eddieeddie
0 Front brake is terrible
Last Post: Yakcm2
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Bow only
NedNimrod, jduffy01, AlanT (71), jzink0883 (70), LVBOATDOC (67), glef (62), Dogsbd (57), wmbettsjr (43), darkcustom (42), jon8641 (35)
Old 27th July 2018
Did you check the Sportsterpedia?
It has info supplied by the 1996 manual:
http://sportsterpedia.com/doku.php/techtalk:evo:elec01
Your 1991 may or may not be exactly the same - but 18ga specified for 1996 should be fine - Except for the TSM incoming power wire - 16ga...
2 Relax
Old 27th July 2018
chris16371 chris16371 is offline
Sportster/Buell Year: 1991
chris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to beholdchris16371 is a splendid one to behold
I went to Sportsterpedia and looked under TSM to look for the location or a picture, I did find a diagram of the wire location and color on the connector. I'm wondering if that's my TSM in the pic.
Sent from my SM-G892A using Tapatalk
Old 27th July 2018
It looks like it.... That's a narrow angle... It should look like this:
2 Relax
Old 27th July 2018
2 Relax
Looks just like it, it's behind the ignition module.
Apparently the wire function isn't labeled on the TSM for 1991? I can't see to see it on your pic or on my module. Good thing Sportsterpedia has that information.
Old 27th July 2018
Be careful - I think the SP has the right colors/functions...
But - Can you take a nice clean picture of the TSM out of the mount with the cable connected - that shows exactly what color wires goes to which pin locations?
It would be much appreciated - to either confirm or change the SP...
Thanks
2 Relax
Old 27th July 2018
Thanks
2 Relax
Yes I can do that. Give me just a few please. Thanks
Old 27th July 2018
Did you already buy a R/B/T module? Which one?
2 Relax
Old 27th July 2018
2 Relax
Kuryakyn #4859 with Kuryakyn 8 pin connector #4832, apparently it can't be plugged right in so that's why I needed to buy the 8 pin connector. There's a set of connectors that looks like it would fit but I didn't want to try and screw something up if it did fit but wasn't suppose to be there.
Old 27th July 2018
So here is the wiring adapter they recommend to rewire the bike to mate up with that #4859 module (wiring adapter P/N is 4832) - You should be able to make your own based on this info:
https://maggroup.blob.core.windows.n...-21HD-0911.pdf
And here: https://img.jpcycles.com/staticwebfi...df/340-240.pdf
(available at Amazon for $15 - https://www.amazon.com/Kuryakyn-4832.../dp/B0022ZOOKS)
They look like unusual connectors - But supposedly mate up to the 4859 module...
The 4859 module install instructions can be found here - but they basically say, just plug it in:
https://www.lidor.pl/media/productsa...ja_montazu.pdf
2 Relax
Old 27th July 2018
2 Relax
Here's the pictures of the TSM.
I also included a pic of where I thought the R/T/B module might fit. It's the black connectors that are together and the white ones that aren't plugged in are the R/T/B. I already have the adapter #4832, was only $10 on eBay.
