Last Post: xlerate
0 Need some advice on 1983 Ironhead
0 Lawwill XR cam cover
Last Post: vee2win
0 Torx screws on clutch cover
0 lithium battery
0 Start up
Last Post: mickey t
0 45740-62 & 62A differences?
Last Post: davidbarker8
Last Post: 4th of July
Last Post: jzink0883
Last Post: Lone Rider
0 ironhead xlh 82 oil problem
Last Post: owlsplace
Last Post: mickey t
0 gearing is too high ?
Last Post: Ronan978
0 Bike can't go over 75miles.
0 Grenade Plate
0 off idle stumble progress
0 A Day in the Life...
0 Sadly Leaving
Last Post: priell3
funnythebunny, abtanner (88), bobby0824 (73), mikeabe (71), CSR (60), mus, evade49 (53), McC2430, bickel417 (33), rabbitsio (29)
KrakerJak KrakerJak is offline
Sportster/Buell Model: Xlch
Sportster/Buell Year: 1972
Sportster/Buell Model #2: 883-1200 converted
Sportster/Buell Year #2: 1991
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1975
KrakerJak is an unknown quantity at this point
Default 95-96 Evo Sporty Clutch Cable Differences
Hello all. Quick run down.... Engine in my 91 1200 converted is shot as I previously inquired about an engine builder. Well I've decided to get me back on the road quickly, for now, I'm buying a 99 1200 donor bike and swapping engines. I currently run a Labriola Jockey Shift setup. After researching clutch cable applications, it seems the range is 90?-95 and 96-03. I know I'm getting ahead of myself, which is normal for me, but my question is what is the difference in clutch cables between these year ranges? Will I be able to swap my kit over with no modifications? I'm attempting to save precious time and get all my ducks in a row and work out any kinks ahead of time. Any input is much appreciated.
Air-Cooled Forever
The clutch ramps are different between the '91 and '99. '91 has the clutch ramp behind the primary cover and the '99 has the clutch ramp behind the derby cover. Differences are probably the length and where the cable adjuster is located.
I do see the difference there. The cable I am running came with the kit, no adjuster present. Judging from pictures I've seen of the 99 and my current primary cover, it looks as if the cable still enters the "primary" at the same point on both years. I guess other than length I was also worried about cable ends being different, or how it connects to the ramp.
Here's the parts listing/diagram for both 1991 and 1999:
http://partsfinder.onlinemicrofiche....TCH%20ASSEMBLY
And here's the Sportsterpedia section on the clutch:
http://sportsterpedia.com/doku.php/t...vo:priclutch01
You should note that the actual cable coupling is the same part (34920-86A), BUT, the Ball & Ramp assembly are different & they mount different in the primary cover... So the cable may interchange if the length is right for the bars you are using...
1991 does not have an oil seal at the primary cover while the 1999 parts shows one there...
Tonyb65's Avatar
Tonyb65 Tonyb65 is offline
Sportster/Buell Model: XL 883 DLX Sportster
Tonyb65 is a glorious beacon of lightTonyb65 is a glorious beacon of lightTonyb65 is a glorious beacon of lightTonyb65 is a glorious beacon of lightTonyb65 is a glorious beacon of lightTonyb65 is a glorious beacon of lightTonyb65 is a glorious beacon of lightTonyb65 is a glorious beacon of lightTonyb65 is a glorious beacon of lightTonyb65 is a glorious beacon of lightTonyb65 is a glorious beacon of light
Barnett has the clutch cable your looking for you can compare the different years there.
clutch cable for 88-95 XLH 1200 is 101-30-10022
for 96-01 XLH 1200 is 101-30-10021
