0 Rear master cyclinder bore size
Last Post: Truckedup
0 Hey everybody!
Last Post: old dog
0 super b overflow
0 Tachos, heads, drives abd Cables
0 using oil
0 Replacing Oil Tank
Last Post: ofaloto.tupi
Last Post: dodgetrucken
0 What Petcock
0 Progress
0 For Sale: 2012 XR1200X
Last Post: sportymas
0 Rebuild
Last Post: sportysrock
0 Bleeding brake
Last Post: mickey t
0 head and cylinder painting
Last Post: RoadsterMike
0 Bulbs
Last Post: BigMek
0 Bike lost power,back fired and stalled
0 Efi and carbs
Last Post: Cmd11
0 horizontal mill
0 Primary/gearbox chirp
0 Need to part with my '59
0 Converted 883, head questions
0 Kickstarter return spring
toby61, Stairman (74), Greywolf (70), federico (67), Big D (66), robin82732 (55), jbd777 (49), Steve3888 (47), RIORoosen (45), NXC1978 (41), JeffsJeep04 (34), Matt.loup.t
Old 21st May 2019
Sportster/Buell Year #2: 2008
Default Same Size Battery Jump Ok?
Originally Posted by LLOYD883 View Post
General question for the experts - can Lithium batteries be boosted like the old lead acid ones if they ever discharge enough to need it ? Or would this cause harm to the electronic circuits in the battery ?
Can I jump a small motorcycle sized lithium battery from an automobile?
NO. It is not a good idea to “jump” a motorsport battery from a car or truck battery. It is much better to re-charge it if at all possible. On the top of each battery is a label that will specify the maximum amount of charging amps to use and a “jump” start from an automobile is about 150X more amperage than maximum amperage recommended, if not more. This can cause the cells to rupture and even catch on fire. This is true for all batteries, lithium or lead acid, if you must jump start the battery, do it from a like sized battery. A lead acid is much more tolerant than a lithium battery as they absorb the charge completely different. It is perfectly fine to jump start the EarthX battery from another motorcycle sized battery or use a jump pack.
Old 21st May 2019
Default One More Try
Beware, some vendors that sell through Amazon will not get you a warranty.
Ordered a Earthx ETX24C from the manufacturer.
Anti Gravity was a close second but due to the ECU relocate had a little less room and the A-G battery was on the edge power wise. Customer service spot on and reviews are good. Also A-G was less expensive.
Old 21st May 2019
XL Ed's Avatar
XL Ed XL Ed is offline
We sold them through the store for a bit. The trick withe was they had a 2 year warranty. A year longer than Yuasa. Sounds great so far. Unfortunately it was from date of manufacture, not date of sale. We only found out about it when we had one, the only one I might add, come back.
Old 22nd May 2019
LLOYD883's Avatar
LLOYD883 LLOYD883 is offline
Sportster/Buell Model: xl883c
LLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud of
Thanks a lot !
I've been considering going Lithium but for twice the price of stock which lasts on average 7 years for me I don't think it' worth it.
2005 883XLC - 42 slow jet, 2 1/2 turns out - N65A needle shimmed 0.030" with stock 170 main jet - 07 1200 W cams - mildly ported stock heads - Arlen Ness Big Sucker air cleaner with HD round nostalgia cover - Khrome Werks 3" tapered slip-ons - SE 1200 ignition module - microTach - Mustang "solo tripper" seat - 12 1/2" Progressive 412 chrome rear shocks.
Old 22nd May 2019
Air-Cooled Forever
When I was in my 20's, I watched a guy jump start a chopped Sportster from a car. When it wouldn't start, he had the guy who owned the car, start the car, to give it a boost. That started his wiring on fire. Few years later, I told another guy about this and he said that as long as the car is not running, the wiring and battery should be OK. So, I have jumped mine using a car battery a few times (car NOT running) over the years and experienced NO problems. I do realize, if you have your bike hooked up to a car (car NOT running), you can't crank on it too long before things get hot. But when it comes to Lithium batteries, your guess is as good as mine.
Old 22nd May 2019
Nibelungen's Avatar
Master Bike Builder
Too early for lithyum
IMO useful only on supersport bikes for weight shaving...
on a Sporty for the moment it does not worth to bother with the cons
a question...
brand new HDs have them stock?
rainbows from other worlds have colours that i don't know
Old 22nd May 2019
Default HD Lithium
a question...
Called the local H-D dealer. He said they were still trying to get a handle on the lithium batteries that they sell and would call me back.
He did not call me back.
Old 22nd May 2019
Air-Cooled Forever
a question...
An answer to your question: I e-mailed my local dealer and they said that they (Lithium batteries) are not available as standard equipment. The customer would have to by one separate, from the dealership, and have it installed.
(side note: they sell little chargers to go with them for around $50)
