0 Searching for a used Ironhead, my observations
Last Post: stavenironhead
0 Keith Black Conversion
Last Post: hexnut
0 03 xlh 88"
Last Post: splineman
0 Lithium battery earthx
Last Post: Tucsonmax1
0 How stock is your bike
Last Post: sportysrock
0 Roky's impulse buy 2001 Kawasaki Concours
Last Post: Sportycus
0 Question on a transfer valve
Last Post: paulc
0 Vintage Stinger Ignition
Last Post: stratoblaster
0 Relocated Turn Signals
Last Post: priell3
0 09 Buell XB12 crank
Last Post: Boudwood
0 Question of the month?!
Last Post: c1skout
Last Post: Caustic Dick
0 Help with my clutch please
Last Post: DirtyHarry68
0 tried something new in my primary
Last Post: Lone Rider
0 Keith Black 10:1
Last Post: 1HD4CJM1X4K
0 My 1978 Ironhead
Last Post: VXDspud
0 Hi from the UK
Last Post: VXDspud
0 Gravydog crashed again.
Old 21st June 2018
doodah man's Avatar
The factory manual shows/describes the procedure to check the big end bearings; it’s easy to do. Basically you measure how much you can rock the arms from cam side to primary side with them at the top of the stroke, then you pull straight up on the rods and push down. The first test can be over the spec a little and be alright, it the up/down test can have zero play.
Old 21st June 2018
Gold Member's Avatar
Sportster/Buell Year: 1972
yeah I did a quick check on the rear rod and seemed like a lot of side-to-side play and no up/down, but I'll look at it again today...now that I have the pistons off the rods...the front wrist pin came right out and I had to press the rear one out with a c-clamp, not sure if that means anything--oh and I scraped a little metal out of the wrist pin hole because it just wouldn't clear with hand pressure like the front one did...well anyway the pistons and junkola anyway
Old 22nd June 2018
DirtyCory's Avatar
Sportster/Buell Year #2: 1972
Other Motorcycle Model: Sportster 48
Other Motorcycle Year: 2010
DirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud of
When you are checking for up and down play, wash the oil out of the bearings first. You will get a much more accurate feel.
The clearance, if memory serves is .0005. You can't feel that unless you're really good or maybe superman or something.
What s up doodah?
If your gonna do something, do it right!
Old 22nd June 2018
doodah man's Avatar
Originally Posted by DirtyCory View Post
...What s up doodah?
oh you know, just the usual antics!!! nothing special...
