9 CV carburetor gurus...
Last Post: Dougray
0 2005 Carburetor Troubleshooting
0 Resto-Repair 84 ironhead
Last Post: Kbetts
0 1970-71 XL Fuel Tank ?
Last Post: Whitewalls
14 Installed Vulcan 3 Degree Raked Cups
0 Who runs 70wt. oil
0 Progressive 444s vs Bitubo twin adjustable
Last Post: Kbetts
0 Low Profile Scissors Lift
0 1960 XLCH in the UK
0 Spark Plugs
0 Leineweber camshaft
4 greetings from quarantine!
Last Post: rubine
0 Clutch cable help (length)
0 Oil pump, ignition coil, head pipes, baffles
0 Magneto upgrade questions
0 2019 xl1200 suspension upgrade
Last Post: Bob F
0 Clutch spring tool/pinion gear tool
timing, timing with voes, voes
Old 24th June 2014
xl2000883/1200 xl2000883/1200 is online now
xl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to behold
I set my mixture screws by the idle drop or hang method and don't care too much what happens to the idle while turning the screws.
I make a adjustment and blip the throttle. And see what the idle does. Hang, dip low, or settle to a steady idle right away........
And its a small blip.
Old 24th June 2014
Csaszar Csaszar is offline
Sportster/Buell Model: Xlx ironhead 1000
Sportster/Buell Year: 1983
Csaszar is an unknown quantity at this point
I'll give that a shot ... Thanks guys
Old 24th June 2014
Folkie Folkie is offline
Originally Posted by Csaszar View Post
since my other post wasn't responded to maybe starting another new thread will catch someones attention.
No, please don't do that. If your thread isn't getting any replies, bump it up: post to it to bring it back to the top of the active threads list.
With the number of posts on here, it doesn't take long for a thread to disappear off the first page. It's no use leaving a thread alone for a week, and then complaining that you have no replies!
BTW, there is a lot of info on carb tuning here, in the Carb Tuning And Jetting Sticky Index.
Old 24th June 2014
I want a more broad area of input maybe something that worked for someone else not necessarily on an ironhead
