Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Tires, Wheels, and Brakes
Last Post: Blue Scoot
0 Getting Hammered
0 Leineweber camshaft
Last Post: chevelle
0 question for our machinists
Last Post: JonesL
0 More oil return questions
Last Post: Scott
0 WTB: Sportster Shift Lever
Last Post: tussuck
0 Mid or forward controls.
0 2015 sportster charging
Last Post: Scott
0 Cheap 7200B bearing = NO!
Last Post: Roane
7 Ironhead yes or no
0 New Member and a question
0 piston rings
Last Post: Sprtstr1200s
0 Cold weather pants:
Last Post: RDHenley
0 Electrical question
Last Post: RDHenley
2 Humble pie
Last Post: RDHenley
0 oil return for stroker
Old 22nd March 2016
cycowrencher's Avatar
Default ID this buell fork and wheel.
I need to replace the bearings, and i have no idea what to buy. It has a solid axle. Does this use the 6204...
Sent from my LG-LS995 using Tapatalk
Old 26th March 2016
The wheel does use the 6204-2RS bearing. This has .75 id x 1.85 od x .50 w. The wheel uses a solid .50 od axle. The wheel was also missing the axle spacer, and I got lucky ordering one off American Sportbike. Now the wheel is back together, but I still don't know what the frontend originally came off of... The original top clamp had cast in bosses for clip on bars.
Old 26th March 2016
onebrkbstrd's Avatar
onebrkbstrd onebrkbstrd is offline
Sportster/Buell Model: xl1200l
onebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond repute
Looks like mine. Mine was 98 s1.
Old 26th March 2016
I have the matching 1 in axle rear and a swingarm that will mount to a rigid sporty frame. I think maybe next year ill go + 6 with that and the buell wheel and stuff a 180 on the back...
