Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Tires, Wheels, and Brakes
0 Getting Hammered
Last Post: kltrkmpf
0 Leineweber camshaft
Last Post: chevelle
0 question for our machinists
Last Post: JonesL
0 More oil return questions
Last Post: Scott
0 WTB: Sportster Shift Lever
Last Post: tussuck
0 Mid or forward controls.
0 2015 sportster charging
Last Post: Scott
0 Cheap 7200B bearing = NO!
Last Post: Roane
7 Ironhead yes or no
0 New Member and a question
0 piston rings
Last Post: Sprtstr1200s
0 New member softail rim laced to sportster hub
0 Cold weather pants:
Last Post: RDHenley
0 Electrical question
Last Post: RDHenley
2 Humble pie
Last Post: RDHenley
Old 25th February 2011
Uneedaraptor Uneedaraptor is offline
Sportster/Buell Model: 883
Uneedaraptor is an unknown quantity at this point
Default Will 1996 buell PM wheels fit 1992 883?
Will these wheels be a direct bolt on or does it require some fab work?
Old 8th August 2014
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Bump. Are the pm chicane wheels extremely light?
Sent from my SCH-I545 using Tapatalk
Old 8th August 2014
Quazy M's Avatar
Quazy M Quazy M is offline
Sportster/Buell Model: XLH 1200 C
Sportster/Buell Model #2: XLH 1200 C
Sportster/Buell Year #2: 1999
Quazy M is a name known to allQuazy M is a name known to allQuazy M is a name known to allQuazy M is a name known to allQuazy M is a name known to allQuazy M is a name known to allQuazy M is a name known to allQuazy M is a name known to allQuazy M is a name known to allQuazy M is a name known to allQuazy M is a name known to all
Without having them on hand there is now way to know for sure, HD only owned 49 percent of Buell during this time and those bikes sharing the same brake caliper, rotor, and hub specs and being two different types of bikes the chances are slim.
Old 23rd August 2014
maru's Avatar
maru maru is offline
Sportster/Buell Year #2: 1996
maru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud of
They are not exactly the same weight as the non Pm tuber wheels, but they are close in weight. The Pm rear wheel is a half inch wider. Both are lighter than a typical XL wheel and neither are as light as an Xb wheel. The Xb wheels are crazy light. Buell also made some magnesium versions of the XB that are lighter still.
None of the Buell wheels is a direct bolt on for any Sportster.
Old 24th August 2014
madnss's Avatar
Thanks Steve, I just picked up a complete xb front end to bolt on. I recall a guy saying that they were about 15lbs lighter than the tube front ends. Not for sure though. This seemed like the logical route considering the price of drag wheels and pmfr front ends.
Ill end up fitting the 1/2" wider xb rear wheel on this winter, but i think i have to change brake and sprockets.
Old 25th August 2014
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
XB front end is light, but not 15# lighter than tuber stuff. Maybe 7-8#, which is still crazy. I put an XB front end on my last S2.
Love is the never-ending act of forgiveness - Peter Ustinov
maru's Avatar
In my opinion, that is e cheapest way to go for light wheels.
Phelan's Avatar
"Take this. It will help you on your way"
http://xlforum.net/forums/s...d.php?t=608852
