Last Post: thefrenchowl
0 Battery melt down
Last Post: koolbreeze
0 Greetings from Denmark
0 Howdy ya'll
0 Resto-Repair 84 ironhead
0 Hello from Tampa, Fl
Last Post: chilly
0 1960 XLCH in the UK
Last Post: chilly
0 88ci Sport Rod
0 removing clear coat on fork lowers
Last Post: jazzman
0 Another from the Phoenix area
0 48 O2 sensor?
0 Phoenix AZ
0 Hello from Philadelphia, Pa
Last Post: ronccc
0 Starting issues (No Spark)
Last Post: marcusorelius
0 [Ignition] Points in a 2000n evo
Last Post: lostjohnny
0 back to factory clutch
Last Post: stick shift
0 Getting Hammered
Last Post: Bryan83taco
0 1968 Vin number help
generator, ironhead, regulator, voltage
Old 7th September 2011
Jmcnam11's Avatar
Jmcnam11 Jmcnam11 is offline
Sportster/Buell Year: 1987
Jmcnam11 is an unknown quantity at this point
Default Generator light stays on 1981 ironhead
Hi everyone. My generator light just started staying on constantly. Before, the light would come on at a low idle and when I would rev the motor it would go out. Now it just stays on. I haven't ridden it since because I'm afraid the battery isn't charging. The generator is pretty new, but the voltage regulator isn't. Could it be the voltage regulator? When I was in sturgis I noticed the headlight would go from dim to bright at night also.
Thanks any help is appreciated.
chief's Avatar
chief chief is offline
Location: mostley at home sometimes in the garage next to my sporty..
Sportster/Buell Model: XLH 883..
Sportster/Buell Model #2: XL 1000
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Yamaha XJ 900
Other Motorcycle Year: 1991
chief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of light
it could be the regulator.. but you can never know for sure if you don't measure with an multi meter..
typo's are just a way of saying: hey i'm dutch!
the dutch Sportster Chopping Bastard.
CTFS
MN Mailman's Avatar
MN Mailman MN Mailman is offline
Sportster/Buell Model: AMF XLS Roadster
Sportster/Buell Year: 1981
MN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of light
Could be either genny or reg. As said, you'll need a meter to find out.
Great info./tests here. I had the same problems earlier this summer.
http://xlforum.net/forums/s...ad.php?t=39146
Question Authority
Tin Man 2's Avatar
Tin Man 2 Tin Man 2 is offline
Sportster/Buell Model #2: XL1200, 2003
Other Motorcycle Model: Suzuki T250 Hustler
Other Motorcycle Year: 1971
Tin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond repute
I got tired of screwing around with the Gen/Reg crap and went with the integrated unit from JP cycle on the Iron head, No more problems.
Old 8th September 2011
Originally Posted by Jmcnam11 View Post
Hi everyone. My generator light just started staying on constantly. Before, the light would come on at a low idle and when I would rev the motor it would go out. Now it just stays on. ...
The brushes are sticking in the generator. Easy fix.
Remove from bike [2 electrical terminals left side, two bolts right side] tip outer end down toward 5:00 o'clock, wiggle it out.
Dismantle the outer end; it will be filthy inside so spray inside with electrical contacts cleaner.
Test brushes and brush springs with your fingers - they should work smoothly; if not ask here about how to fix them.
Measure the brushes - should be > 1/2"; if not buy replacements.
ironowner's Avatar
ironowner ironowner is offline
ironowner is on a distinguished roadironowner is on a distinguished roadironowner is on a distinguished roadironowner is on a distinguished roadironowner is on a distinguished road
Default genny/ohm question
with all wires disconnected, ohm meter shows both A and F poles are grounded to the genny housing. is this correct, because i don't think it is...
"I see that you speak with the ease and assurance of the unconsciously ignorant." - Tommy Smothers...
Old 9th September 2011
Both terminals should have insulating bushings part number 5911 outside the case. One, i do not know which, needs an insulator 31098-58 inside as well. No harm done if both are insulated.
Be sure to do only the tests from the Sticky and from the factory service manual. Do not experiment unless you do understand the electrics of how the gen works.
External insulators ...
You can see the head of the terminal bolt, and the spade terminal behind it. I believe that there should be a thin [cardboard?] insulator behind one of the spade terminals ...
ironowner's Avatar
in my blurry mind, it would have to be the single wire that is the ground and doesn't warrant an insulator, as the green wire connects to it. i am taking your tip and insulating them both with washers made from a styrofoam plate. thanks again Mick.
Neither of the wires at the gen is a ground. The green is output to the regulator. The tan wire[s] run to the gen light and the reg.
ironowner's Avatar
o wise and helpful one! rebuilt it this morning, and the green wire post was not insulated but the tan was. now the tan is not grounded to the gen case or the green post as it was before i started. i had a weak spring on one of the graphite blocks, so i made a shim to go behind it to buy some time, then i'll replace the springs and blocks all around. thanks again.
