0 82 XLH struggling for power
Last Post: darkgizzard
0 Sifton cams on stock 74 XLCH
0 Hydrostatic fuel gauge
0 Microsquirt EFI Conversion
Last Post: Curbside
0 55* this morning
0 1968 ex barn dweller thread
0 Flat Tracker Pics
Last Post: nutball73
Last Post: skien
0 Umbilical Hernia surgery report
0 my sunday driver...
0 -65A mufflers
0 carbs?
Last Post: jtoaster
Last Post: Robyart
0 Chasing a generator noise
0 Better Brakes
0 Opinions on Mallory unilite ignition
Last Post: mikethebike61
Last Post: oldboy
0 S&s
0 Installing jugs finally but another Q
0 Li/Ion battery in '03
Last Post: Eric Von Zipper
0 Late-model stator on rigid-mount bike?
Last Post: Curbside
ebikerman (84), nalakk (79), blkjak (77), Dave.N (66), cousincletus (60), stretch7 (58), jockeyshift (56), juice900 (42), sportsterwheelies (40), live_loud (38)
anti-rotation, cams, screws, tappets
Old 19th June 2013
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
Originally Posted by hairy View Post
this makes me worried about my new build.
hammer sent me h.d lifters for my crush 600 cams, I hope I don't have any problems.
I'm pretty certain they have you covered. Shoot Aaron an email and see what he says.
"We've done four already but now we're steady
And then they went: One, two, three, four"
“The larger brush provides coverage, but is incapable of detail.” - Sherwin Williams
“How can you have any pudding if you don’t eat your meat?”
Old 19th June 2013
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
don't know if id run that lifter or not nores xl has killed 2 sets I think id spend the money and get some jims but buy the look of thoughs pins Id say they hit the lifter. side to side on the roller is ok its up and down you worry about but did your pins have wear to begin with and allow it to move.? and look at the top of the lifter cover make sure they don't hit.
Old 19th June 2013
rejeanprimeau's Avatar
Originally Posted by groovemeisterus View Post
Are you referring to oversized lifters and bore? Similar to next oversized sized pistons in the jugs?
I've saw tappet blocks so bad, they send the lifter right and left. In a high performance motor, the lifter or tappet block get overlook often. Just make sure you check them. S&S sell high performance tappet block. Just imagine the wear they suffer just looking at your antirotation pins.
Old 20th June 2013
90sportster's Avatar
90sportster 90sportster is offline
Sportster/Buell Model: 883/Hammer 1250
Sportster/Buell Year: 1990
90sportster has disabled reputation
. Sometimes, when engine starts to make that noise(almost embarrassing), like described, and I come to a stop light after a long ride, engine idle will be higher, and will have to adjust idle on the fly, then several more miles, when have to stop at another light, idle might be too low, and then have to re-adjust. Not always, but another symptom.
Cold starts are fine, and runs decent when cool, but after engine gets HOT, here comes the noise.
I have these exact same symptoms as of late.
Running Andrews V4 cams.
Been running it pretty hard since break-in of the conversion.
Going to put in some Jim's Powerglides.
Already have the S&S tappet blocks.
Disclaimer: What I say is based on my knowledge and experience only. It's entirely possible I'm full of shit. You've been warned!!
HAMMER PERFORMANCE:
1250 kit w/30* reverse dome pistons
SMASH CNC Head Porting Service on 883 Heads
Air Hammer 'CRUSH' A/C
Billet Intake Manifold
Sledge Hammer Pushrods
ANDREWS: V4 Cams
S&S: Lifters
MIKUNI: HSR42 Carb
DYNATEK: D2KI Ignition
RB RACING: LSR 2-1 Prostock Exhaust
'07 BUELL: Oil Pump & Bronze Drive Gear
ZIPPERS: Billet 4 Speed Trap Door
PROGRESSIVE SUSPENSION:
Springs up Front & 430's on the Rear
RICOR: Intiminators
SUPERBRACE
HHI: 6 Piston Front Brake Caliper
And the list goes on
Old 20th June 2013
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to behold
Post
Originally Posted by ~Grind~ View Post
Do you think the lifters collapsing would cause the damage to the anti-rotation pins?
Would you post pictures of the lifters please?
That i'm not to sure on. I'll post some picts tomorrow when I get the chance. There is wear I did see. Need to try and get some picts from the lifter tubes themselves also.
But as my knoweldge goes on lifters, when they collapse, pressure is lost on the pushrod, which causes the valves (via valve springs), to slap back, which which cause some wierd valvtrain movements etc. I'm just now learning and getting up to speed on lifters. Never thought a lifter could effect the engine like this. But i'm slowly learning that it does.
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Old 20th June 2013
Post
There was never any wear on the pins when first installed S&S lifters about 4 years ago.
Bob woods gave me a number to a sportster expert, and he uses the Feuling lifters on all his sportster engine builds and never had any problems with them. HOT builds, 88" 90", etc, and running above .600" lift cams. can't remember exact lift, .65 or higher maybe, but no issues he's ever had with those lifters is the main thing i got.
Old 20th June 2013
Post
Very true on overlooked often. I'd never even thought could be lifter issue. But now i'm learning about lifters now, since never even thought they could go bad, or wear out the lifter bore and make it larger. Good stuff to know.
Thanks
Old 20th June 2013
Lightbulb
Good to know others out there are experiencing the same symptoms. As stated before, all was good, but like any custom rodded engine, wear and tear happens when ya run them hard. I'm gonna look into them tappet blocks and see what there all about, what they do, and how to install. From first looks, seems like need to bore tappet holes, then place the tappet blocks? Again, these tappet issues are all new to me.
Thanks for your feedback!
Old 24th June 2013
Post Lifter Picts
Here's a shot of my lifter's as asked for. I put the feuling lifters in already, and have only experienced somewhat of a very slight noticeable similarity. Valve train sounds normal for cams, but has not yet got HOT enough to make the same similar noise, and idle offset ect as the last S&S lifters did. Need some longer rides and hotter temps to be for sure.
I am running SE -0.50" push rods though. I am curious though if that would be a significant factor of being short by that much. Used those for extra protection of valve to piston contact.
Again not sure, but hate to have to use adjustable push rods, but wonder if that much difference, after engine is up to optimum operating temp, if valve train could be thrown off.
Can def see wear on the lifters in the following pict...
Thanks again for any feedback.
Old 24th June 2013
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Pushrod length doesn't change piston to valve clearance.
Click Here to Contact Me
