Last Post: iBloke
0 1968 ex barn dweller thread
Last Post: fernf5
0 Opinions on Mallory unilite ignition
Last Post: Heff
Last Post: Andy56
0 Installing jugs finally but another Q
0 fork oil change with Ricor intiminators
0 Better Brakes
Last Post: mrmom9r
0 Li/Ion battery in '03
0 Tools
Last Post: denguy
0 18” rear wheel mag
Last Post: Yourstrulythom
0 Microsquirt?
Last Post: Curbside
Last Post: gusm2
0 Arlen Ness F-Bomb Pipe Test
0 Brake light issues
Last Post: night-train
0 Microsquirt EFI Conversion
Last Post: Randy_rots
0 Sifton cams on stock 74 XLCH
Last Post: lajam175
0 -65A mufflers
Last Post: DR DICK
0 Chasing a generator noise
Last Post: DR DICK
0 55* this morning
0 2007 883R From Sunny Old England!
lineberger, 39dan (62), FstPig (61), jmdajd (57), ironhead 74 (57), erjasn84, Bada Bing (56), ottchuck (55), OutlawTexan67 (53), RAJ (47), Wintersdark (44), robychopper (44), TnsporT (43), MotoSquirrel (36)
cams, oil breather, popping, timing
Old 1st June 2015
Urhahn99 Urhahn99 is offline
Sportster/Buell Year: 76
Urhahn99 is an unknown quantity at this point
Default Popping while idling
I have a 76 ironhead that for the life on me I can not figure out what the problem is. Bought the bike and finished assembling the motor and complete bike. Couple problems running into. I got the engine to start but it pops horribly. Checked cam timing and oil breather timing. With slash on flywheel center in hole oil breather mark is slightly off. Second problem is lining all cams up, exhaust cam on no. 1 cylinder seems about half tooth off the intake cam. Any help would be appreciated.
Old 1st June 2015
Please post a pic of the cams showing the marks. Get down low with the camera so that the view is straight on, not on a down angle. No flash, just soft light to avoid reflections, bright spots, etc.
Under what conditions does the engine pop? at idle? at hiway speeds? on decel? accel? whatever.
See cam install pics in the Stickys. Here's one ...
How to Install Cam Gears in your IronHead
http://xlforum.net/forums/s...d.php?t=239641
Old 1st June 2015
Fridge's Avatar
Fridge Fridge is offline
Sportster/Buell Model: XLCH/H
Sportster/Buell Year: 1973
Other Motorcycle Model: Road King Classic FLHRCI
Other Motorcycle Year: 2007
Fridge has disabled reputation
The breather being off a little bit is no biggie. As long as the dot is in the notch by at least 70%.
Timing the cams, to that same timing mark is the wrong way to do it,if that is how you are doing it.
You time the cams with the pinion gear in the 11o'clock position and looking straight on them to line them up correctly.
Iron Mick's request for pics will help very much in determining the problem...
Old 1st June 2015
I will try to get pics some time this week when I have a chance to work on it again. I had a old bike mechanic do it twice and swears its exactly how its suppose to be. It starts popping as soon as it fires up. Have not revved it up at all or put it on the road. Thats how bad the popping is and do not want to cause more problems. I also read on here somewhere that the oil breather is supposed to be time at the 40* advanced mark, is this true or just time it tdc?
Old 1st June 2015
From the Stickys. Should be pic's in here ...
Timing the Oil Pump
http://xlforum.net/forums/s...d.php?t=170686
Oil pump timing. Cam timing. Ignition timing. Intake and exhaust leaks. Carb cleaning and tuning.
The Stickys start here. Hours, days, months even, of good reads ...
Technical Stickys Index - TuneUps, ReBuilds, Etc, Etc, Etc
http://xlforum.net/forums/s...d.php?t=465866
Old 1st June 2015
Need more clues.
Popping in the exhaust? in the intake?
Does it get worse if you gas it?
Popping tops? Popping pills? Popping tags? :^)
Old 1st June 2015
Fridge's Avatar
Advance mark, the line on the flywheel for stock flywheels.
Obviously you don't have the FSM(of which you should have),so,your next best helper is to read thru the stickies Mick has suggested to get some more insight on these old beasts.
Old 1st June 2015
78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light
Check pushrod adjustment, intake might be too tight making it pop out of carb.
Old 1st June 2015
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Quick and easy check.
Put a pressure guage on both cylinders. Check the stickies for the correct procedure.
If they both have a reading within 5 lbs of eacj other it's not cams. push rods or valves in anyway. I will presume since it's a fresh motor they will run somewhere around 170-180.
If there is no problem there it's either ignition timing or fuel mixture.
I'm betting timing. These things are very "finicky (technical term - means you need to be accurate) about ignition timing.
Quick check on the ignition timing problem.
Retard the ignition a tad and see f the problem persists.
Play Carefully
Gene
Old 16th July 2015
Sorry guys I havent replied in a while. I figured out my ignition was bad. Coil would fire when key was turned off. Upgraded to the ultima ignition and problem solved. Now to just finish working out the last few little kinks in the bike.
