0 Hydraulic Lift For XL
0 question for our machinists
Last Post: yoshi
0 supply oil line seeping
0 Fact or fiction?
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
0 Very Loud Backfiring (among other things)
Last Post: Nacs
Last Post: olrider
0 Interview of My Expieriences Riding in the Iron Butt Rally
5 Crankcase Oil Drain Plug
0 Winter riding clothes
0 Question on priming motor for kickstart
Last Post: kobra50
5 Your worst car?
Last Post: dodgetrucken
5 73 Timing w/Strobe & 77 air/fuel screw
Last Post: 4th of July
0 Speedometer Interchangeability Between Different Generations.
Last Post: 619Sporty
0 A.I.M. Clutch set up
0 What engine oil do you use?
advance, ignition, retard, timing
Old 8th October 2015
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of light
Question Retard ignition 7 degrees without timing light?
I seen somewhere on here before a better way to set timing on an ignition CONE module from Aaron from Hammer Performance but can't find it. He spoke about
a similar method.
My daytona twin tec 1005S-EX ignition is dialed in with a timing light at 20 degrees BTDC with the 2 dots in the timing peep whole per instructions.
My daytona twin tec ignition has a MAX advance of 30 degrees at curve 0,
and a MAX advance of 35 degrees at curve 9.
Ignition is scribed, marked etc at current rotation location so could be put back quickly.
How would a timing light with advance settings be used to retard to a specific value? or how many .1" or degrees measurement on ignition module itself would it take to retard 1 (one) degree? Counter clockwise.
So if I choose curve 0, and dynamic time it per instructions, my max advance is 30 degrees BTDC.
I want to retard it to 28 degrees BTDC for that curve. How far measurement wise should I rotate the module counter clockwise?
If using curve 9, MAX advance is 35 degrees BTDC. I would like to try that curve also, but retard MAX timing to 28 degrees BTDC.
Any quick tips or pointers to other threads or feedback would be much appreciated.
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Tom Beckner Tom Beckner is offline
Sportster/Buell Model: XLH 883/HP 1250
Tom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond repute
Is this what you were looking for?
http://www.1250kits.com/ttinstallkit.shtml#Tuning
◾If you're using a DTT 1005S-EX ignition, static time the module using the
LED as described in the module's instructions, then rotate it clockwise .030" as
measured at the perimeter of the plate, and set it on curve 0.
you have a dial back light? set to zero and check timing to set if it is correct. now dial back the light to desired setting and then turn ign base plate till you see the timing mark again.
Question
Its's really that simple? Man I think too deep sometimes.
Yes I have a dial back light. 0 timing on light is 20 BTDC (2 dots) in peep hole at idle per daytona twin tec instructions. So at that RPM, stock MAX advance is aprox 26 degrees BTDC in curve 9... at idle.
If i want to rotate ignition module, at idle, to change the MAX 35 degrees BTDC at 2000RPM and above at WOT, while timing with light during idle, so MAX advance will change to 28 degrees BTDC at WOT, I need to take the idle (RPM) max number of 26, set the light to 7(35-7=28), turn module again till double dots come back in to timing peep hole... at idle?
As long as reference (during idle) is at a certain MAX, turing the module changes every MAX advance so the whole curve changes.
Is that correct?
Thanks Tom!
Is that correct?
First step, define what you're trying to do.
With the VOES disconnected, you're trying to get a curve that reaches full
advance, 28 degrees, somewhere around 5000 - 5500 RPM, right?
Tom Beckner
Old 9th October 2015
Tom Beckner
Yes
Old 16th October 2015
if you retard base timing, it is over the whole curve, aka, 15 at base would drop 5 off any adv position in the module unless you have a e2prom and can change timing curves via a computer. one thing to note: setting back the 5 also means you are setting start timing back 5, aka 0 tdc to 5 btdc.
