0 Sifton cams on stock 74 XLCH
0 Hydrostatic fuel gauge
0 Microsquirt EFI Conversion
Last Post: Curbside
0 82 XLH struggling for power
0 55* this morning
0 1968 ex barn dweller thread
0 Flat Tracker Pics
Last Post: nutball73
Last Post: skien
0 Umbilical Hernia surgery report
0 my sunday driver...
0 -65A mufflers
0 carbs?
Last Post: jtoaster
Last Post: Robyart
0 Chasing a generator noise
0 Better Brakes
0 Opinions on Mallory unilite ignition
Last Post: mikethebike61
Last Post: oldboy
0 S&s
0 Installing jugs finally but another Q
0 Li/Ion battery in '03
Last Post: Eric Von Zipper
0 Late-model stator on rigid-mount bike?
Last Post: Curbside
ebikerman (84), nalakk (79), blkjak (77), Dave.N (66), cousincletus (60), stretch7 (58), jockeyshift (56), juice900 (42), sportsterwheelies (40), live_loud (38)
efi, electrical problem, fuel pump
Old 9th May 2018
Mechanick Mechanick is offline
Sportster/Buell Year: 2014
Mechanick is an unknown quantity at this point
Pump always worked—just discovered the wire when changing tanks (in both cases—from original peanut tank to larger capacity and then back—so failure with both original tank and OEM tank). Service at LHD could only suggest a new pump and harness (harness not sold seperately) but that is what I did the first time around (and not covered under warranty). I have to be MORE objective in my LHD sevice comments because I found out they are reading this forum (makes sense).
Old 9th May 2018
Old 9th May 2018
Old 9th May 2018
Repair in blue wiring. Crimped and soldered. Will ride thru a few tanks and check. Note in addition to repair steps outlined in prior posts, also spliced in another ground wire to main ground where it exited the tank and am running that wire straight to frame ground. This will bypass any faulty connection that may exist but which is not showing up in testing.
Old 9th May 2018
That looks like a substantial gauge... Good luck with that... Update this thread when you check it in the future...
2 Relax
FREE XLForum Organized Tech Info - Check Out The Sportsterpedia
Old 9th May 2018
Thank you again for helping to figure this one out. Much appreciated.
Old 9th May 2018
You're very welcome - glad to help...
2 Relax
Old 13th May 2018
wedge's Avatar
wedge wedge is offline
Have you checked the ground straps connecting the frame to the engine? Grounding to the frame is not as definite as grounding to the engine where the battery is grounded, because those ground straps could be broken or just corroded. The path has to make it back to the battery.
I saw a car many years ago that burnt the choke cable in half because the strap between engine and frame was broken or just left disconnected (many years ago and my memory sucks that far back).
Old 13th May 2018
Good point—yes, checked that earlier—all was fine there. (...and between you and me, yes, I’m running that backup wire directly to the negative post but figured if I mentioned that someone would make an opposite case. I want to absolutely insure a solid ground, so going to the post makes the most sense, just not a typical wiring process since normally just the ground strap attaches to the ground post.)
Old 13th May 2018
Good Point, Wedge... From the Sportsterpedia section on Grounding:
2 Relax
