Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle General Discussion and Problems
0 82 XLH struggling for power
4 Rockerbox spacer ´71 XLH
Last Post: Hank71
0 Sifton cams on stock 74 XLCH
0 Hydrostatic fuel gauge
0 Microsquirt EFI Conversion
Last Post: Curbside
0 55* this morning
0 1968 ex barn dweller thread
0 Flat Tracker Pics
Last Post: nutball73
Last Post: skien
0 Umbilical Hernia surgery report
0 my sunday driver...
0 -65A mufflers
0 carbs?
Last Post: jtoaster
Last Post: Robyart
0 Chasing a generator noise
0 Better Brakes
0 Opinions on Mallory unilite ignition
Last Post: mikethebike61
Last Post: oldboy
0 S&s
0 Installing jugs finally but another Q
0 Li/Ion battery in '03
Last Post: Eric Von Zipper
ebikerman (84), nalakk (79), blkjak (77), Dave.N (66), cousincletus (60), stretch7 (58), jockeyshift (56), juice900 (42), sportsterwheelies (40), live_loud (38)
Old 15th March 2019
Stickr Stickr is offline
Sportster/Buell Model: Buell
Stickr is an unknown quantity at this point
Default Buell lightning
Hi all im new to this page as well as a buell owner. I picked up a package deal and got a lightning.. Now im trying to get it started.. And keep it running! In the process of locating a problem ive removed all intake covers. I also found a box (power comander?) Under the seat which says for racing only.. It pops and backfires but wont start...both pluggs have spark.. All ideas are welcome...
Old 15th March 2019
Will it give you any diagnostic codes?
I.B.A.#26543,
Old 15th March 2019
Welcome to the XLForum...
Do you have the manual??? It's important...
http://buellmods.com
Possible Reasons For
Engine Turns Over But Does Not Start
1. Fuel tank empty.
2. Fuel filter clogged.
3. Discharged battery, loose or broken battery terminal connections.
4. Fouled spark plugs.
5. Loose or shorting spark plug cables or connections.
6. Ignition timing badly out of adjustment.
7. Loose wire connection at coil or battery connection or
..... plug between ignition sensor and module. See Section 4.
8. Ignition coil not functioning.
9. Ignition module not functioning.
10. Ignition sensor not functioning.
11. Sticking or damaged valve or valves.
12. Engine flooded with gasoline as a result of overchoking.
13. Engine oil too heavy (winter operation).
14. Ignition circuit interlock malfunction.
15. No output from the ECM. See dealer.
16. Inadequate fuel pressure in fuel lines (possible leak).
..... See dealer.
17. Clogged fuel filter (on pump or in-line).
18. Clogged fuel injectors. See dealer.
19. Tripped bank angle sensor. Turn key to OFF and then
..... back to IGN again to start bike.
20. TPS/fast idle screw not set properly. See dealer.
21. No output from CMP sensor. See dealer.
22. Inoperative fuel pump. See dealer.
P.1-42 - 2002 Buell X1: Maintenance
Check Out The Sportsterpedia
Old 15th March 2019
Sportsterpaul... The box has norhing writen on it other than for race only... No numbers or codes... I had it runing o ce however a bit irratic ... Its fuel injected but seems to flood very quickly
Old 15th March 2019
Not overly familiar with Buells but on the Sportys you can pull diagnostic codes from the speedometer.
Old 15th March 2019
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
I'm guessing this isn't meant to be in 'Racing'; moving to 'Buell'.
Folkie
South East England Riders
Old 17th March 2019
Airbozo's Avatar
Airbozo Airbozo is offline
Sportster/Buell Model #2: S3T Thunderbolt
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XB12R
Other Motorcycle Year: 2009
Airbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond repute
If it looks like this it's your ECM. The "For Race Use Only" ECM has modified maps probably based on the intake and exhaust on the bike.
Post the details of the bike (year, exhaust, intake, etc) and people can provide better help.
Pictures would help too.
Paul's right about the trouble codes. I think it depends on the year on how to do it. Invest in a "Buelltooth". $45 and you can use your smart phone to check codes and test certain things on your bike. Mine works on my 2000 S3 and 2009 XB12R. You can also use it to adjust and or load maps (not sure if the race ECM is locked or not). Lots of free maps on that site too. Tested and verified by multiple riders.
If the bike sat for a period of time, the injectors may be fouled. I used a bit of Seafoam in the gas and it solved an issue I had with rough running (mostly on one cylinder). If you tried to start it with old gas I would almost bet that is the issue. Or at least part of it.
"...Dumb all over, A little ugly on the side... "...Frank Zappa...
Old 18th March 2019
Airbozo you got it. that's the same box. the bike has sat about 3 yrs yes ive cleaned everything tank lines new filter... cleaned plugs as bike has only 4000 miles ( not much for 2002).. I did not take out the injectors though... I have removed the whole intake mumbo jumbo for a cleaner look.. however not sure about what to do with the sensor... my old school mechanical skills doesn't think that should create such a problem... I have filled the tank with 92 octane no ethanol (that's what I use in my bmw) ill check into this buelltooth and have to borrow a buddies smart phone... id like to figure it out.. the closest mechanic (that has a good rep.) is over 100 miles away
Old 18th March 2019
ill try to post pics of the bike and exhaust tomorrow...
Old 20th March 2019
Airbozo's Avatar
My 2000 S3T sat for about 3 years when I bought it with 5000 miles in 2012, and after running some seafoam the engine ran good, but the top end gaskets started leaking, so I had to replace them. I now have 35000 miles on it.
My 2009 XB12R had 503 miles on it when I bought it 2 years ago and it ran like shit (rear cylinder was not runnning smooth). Ran some seafoam through it and after a few minutes it started running great. Now has 13000 miles.
