0 Getting Hammered
Last Post: kltrkmpf
0 Leineweber camshaft
Last Post: chevelle
0 question for our machinists
Last Post: JonesL
0 More oil return questions
Last Post: Scott
0 WTB: Sportster Shift Lever
Last Post: tussuck
0 Mid or forward controls.
0 2015 sportster charging
Last Post: Scott
0 Cheap 7200B bearing = NO!
Last Post: Roane
7 Ironhead yes or no
0 New Member and a question
0 piston rings
Last Post: Sprtstr1200s
0 New member softail rim laced to sportster hub
0 Cold weather pants:
Last Post: RDHenley
0 Electrical question
Last Post: RDHenley
2 Humble pie
Last Post: RDHenley
Old 26th September 2019
PetesPonies PetesPonies is offline
Sportster/Buell Year: '59
Sportster/Buell Model #2: 2004 XL1200R
Other Motorcycle Model: 2006 XL1299R
PetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant future
Default How much wider are the mid glide trees . .
than a narrow glide tree? I can get some 16 x 3 black spoke dual disc wheels from a Big twin, the hubs are 6 1/2" wide. So, I think that could be too wide for a Mid Glide tree. I'm thinking I need to lace a narrow hub to a 3" wheel and then space to fit the Mid glide.
Pete's Ponies Mustang RUSToration & Performance
I talked to Buchanan and they suggested a narrow hub laced to a 16 x 3 rim.
Old 27th September 2019
Will1250 Will1250 is offline
Sportster/Buell Model: XL
Sportster/Buell Model #2: XL 1200 bitsa project
Sportster/Buell Year #2: 1986
Will1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond repute
An inch and a half (I just measured mine as I am doing a 48 conversion on an 04). Narrow glide is seven inches and mid is eight and a half.
You're not talking center to center . .you measured outside to outside?
Old 28th September 2019
Centre to centre (yes, that's how we spell centre over here).
I'll see if I can put some photos up.
THank you very much for the pic!!
Old 29th September 2019
You're welcome
Cheers, Will
madlim madlim is offline
madlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond repute
Just thought I'd add this from vulcanworks site:
Fork Tube Center to Center Spacing Info
39mm Stock 7.000"
39mm Mid-Glide 8.437"
39mm Wide-Glide 9.875"
Old 30th September 2019
Good info; thanks for that.
I initially measured mine with a vernier but used a tape in the photos for ease of viewing. As you can see in the photo, however, mine has no clamp bolts on it which would explain the 0.063" discrepancy.
Cheers, Will
