Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Era Specific and Model Specific > XR Sportster Motorcycle Talk - XR750, XR1000, XR1200
XR Sportster Motorcycle Talk - XR750, XR1000, XR1200 For XR Sportsters: XR750, XR1000, XR1200
0 6 speed
Last Post: seajay
0 8th Air Force memorials in the UK
Last Post: 45Brit
Last Post: dewjantim
0 WTB:2003 Tank Badge
Last Post: BlackBikeDave
0 Bought a '74 today.
Last Post: XL100
0 First real ride
0 Tools for a '74 Ironhead
0 Sportsterpedia Progress
0 Brake pedal adjustment on 09 Custom
Last Post: HS125
0 2016 Sportster 1200 Custom No Stage information
0 Leineweber camshaft
Last Post: 11B40
0 forged pistons?
10 Hello from New York
Last Post: bklyngeezer
0 Thanks For The Add / In Michigan
0 hi all
0 Hello from Seattle
0 More oil return questions
Last Post: thefrenchowl
0 Getting Hammered
0 Free***** S&S re-useable filter
Last Post: duffy
horn, relay
Old 26th February 2009
jp2code's Avatar
jp2code jp2code is offline
jp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to behold
Default XR Horn Relay?
Does the XR have a horn relay switch on it? If so, how would I find it on mine?
I'm interested in changing out that lame "beep-beep" horn for one that goes "honk-honk".
I found some directions online showing how to replace a typical factory "low powered" horn, but it recommends also installing a horn relay if the motorcycle doesn't have one.
I don't know if the XR has a horn relay or where it would be located to check it.
Any help is appreciated.
Can't say for sure, but I do know a bunch of people have installed higher powered or dual horns (like dual fiamms) on late-model XLs without adding a relay. So either it has one, or the circuit can handle it, I betcha...
a45junkie's Avatar
a45junkie a45junkie is offline
Master Bike Builder
Sportster/Buell Model: XLH883/1200
Sportster/Buell Year: 96
Other Motorcycle Model: CX500
Other Motorcycle Year: 84
a45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nice
might be able to tell by disconnecting the horn an pushing the button.
should be able to hear the relay click, i doubt it has one tho
96 XLH883/1200
BUB Reinhart 2-1 exaust fitted with supertrapp muffler 24 disks
big sucker stage one
progressive suspension
Old 27th February 2009
jp2code's Avatar
I can certainly give that a try!
doxbike doxbike is offline
Sportster/Buell Model: FatBob
Sportster/Buell Model #2: all gone 1200R
Other Motorcycle Model: Honda ST1300;Goldwing1500
Other Motorcycle Year: 0407
doxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of light
The Stebel Compact Nautilus comes with a relay. I was told on the xlf that if you didn't use a relay, you would fry the switch wires so I didn't take a chance.
Easy hook up-battery to #30, original horn wires to # 85 & 86, #87 to + side of horn, negative horn to ground.
Check if it can be mounted to the tank bolt (lotsa threads on here) very sano install
All HD's gone now-Riding a Triumph Tiger 800xc and a Goldwing-time's they are a'changin'
ReddTigger's Avatar
+1 on the Stebel on the tank bolt......
States I've Ridden in
71.3 hp 70.8 tq
jp2code's Avatar
I just looked at the reviews for the Stebel compact nautilus air horn. One guy, with a Beuel XR12, said it would not fit.
How similar is the HD XR to the Beuel XR?
I had a dual fiamms setup on my old Honda VF750C and salvaged it when the bike was hauled away. Those sounded fantastic: Like a great big caddy horn!
ReddTigger's Avatar
Although I don't have an XR, it looks like it should mount to the tank bolt up front, it might be a tight squeeze, but there are also other locations you can try..
I find them all the time on ebay for around 35.00
