0 Getting Hammered
Last Post: kltrkmpf
0 Leineweber camshaft
Last Post: chevelle
0 question for our machinists
Last Post: JonesL
0 More oil return questions
Last Post: Scott
0 WTB: Sportster Shift Lever
Last Post: tussuck
0 Mid or forward controls.
0 2015 sportster charging
Last Post: Scott
0 Cheap 7200B bearing = NO!
Last Post: Roane
7 Ironhead yes or no
0 New Member and a question
0 piston rings
Last Post: Sprtstr1200s
0 New member softail rim laced to sportster hub
0 Cold weather pants:
Last Post: RDHenley
0 Electrical question
Last Post: RDHenley
2 Humble pie
Last Post: RDHenley
check engine, relay, speedo not working, speedometer
Old 8th June 2009
bcthomas76's Avatar
bcthomas76 bcthomas76 is offline
Sportster/Buell Model #2: 883 Low
Other Motorcycle Model: Yamaha XS750 triple
Other Motorcycle Year: 1977
bcthomas76 is an unknown quantity at this point
Default Relay Issue???
I just picked up an 06 883 for my wife and the speedo along with the odometer stopped working. The check engine light also comes on after a few miles, if I shut the bike off restart and get going it is fine for another few miles. Runs fine but light keeps coming on.....can it be in the relay? All of the fuses are fine as they were my first of the trouble shoot. Any advice or similar issues? Thanks Bruce
Old 8th June 2009
05sporty 05sporty is offline
Sportster/Buell Model: sportster 1200 custom
05sporty has disabled reputation
there is no relay for the speedo .most likely it is a bad speed sensor, but you should check and clear the codes.you will find a thread on how to check codes.
Old 8th June 2009
jamesr242's Avatar
jamesr242 jamesr242 is offline
jamesr242 is on a distinguished roadjamesr242 is on a distinguished roadjamesr242 is on a distinguished roadjamesr242 is on a distinguished road
Here is the thread you're talking about. I would vote for the speed sensor too, especially if everything else still works on the speedo (ie backlight, switch, etc). Also, do you're turn signals still self cancel? If not, it is another good indicator it's probably the speed sensor.
Old 8th June 2009
dano in kc dano in kc is offline
Sportster/Buell Model: 1200 R
dano in kc is an unknown quantity at this point
Mine did the same thing twice. The first time was under warrenty. (Which didn't matter)
You might have a broken wire. Mine broke in the harness close to the front mount bracket of the tank. I soldered it back together and it works fine. (The dealer didn't do a very good job)
Old 11th June 2009
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Yep.........check your codes and re-set.....after it does it again a time or two.....bite the bullet and buy a new speed sensor. It's kind of a bugger to get in but if you move the oil lines out of the way...it's about a 15 minute job.
After I cahnged mine.....I've had Zero issues.........and my speedo would stop frequently.
Stuff: YES
