Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
0 8th Air Force memorials in the UK
Last Post: 45Brit
0 6 speed
Last Post: stikflote
Last Post: dewjantim
0 WTB:2003 Tank Badge
Last Post: BlackBikeDave
0 Bought a '74 today.
Last Post: XL100
0 First real ride
0 Tools for a '74 Ironhead
0 Sportsterpedia Progress
0 Brake pedal adjustment on 09 Custom
Last Post: HS125
0 2016 Sportster 1200 Custom No Stage information
0 Leineweber camshaft
Last Post: 11B40
0 forged pistons?
10 Hello from New York
Last Post: bklyngeezer
0 Thanks For The Add / In Michigan
0 hi all
0 Hello from Seattle
0 More oil return questions
Last Post: thefrenchowl
0 Getting Hammered
0 Free***** S&S re-useable filter
Last Post: duffy
Old 10th August 2010
BCP's Avatar
BCP BCP is offline
Sportster/Buell Model: 883 XL Sportster
Sportster/Buell Model #2: Buell M2 Cyclone
Sportster/Buell Year #2: 2002
BCP is an unknown quantity at this point
Default Base Gasket removal
Got the piston cylinder off. Trying to figure out the best method to remove the base gasket without scratching the sealing face. The dealer said they use new razor blades. Anyone got a better method. Any kind of chemical to soften it up. This one is black and doesn't feel like paper.
Thanks in advance.
BCP
The things I do might shorten my life, but at least I have a life worth living!
Mattbastard's Avatar
Mattbastard Mattbastard is offline
Bike Builder
Sportster/Buell Model: Sportster 883/1200
Other Motorcycle Model: V-Strom 1000
Other Motorcycle Year: 2014
Mattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of light
Sandblast it off
Seriously. Those stock gaskets are a bitch!
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
Shu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant future
You can spray on some gasket removing stuff. You can carefully go at it with a razor blade. You could try some Goof Off. I haven't tried it but heard it softens it up and makes razor process a little easier. I use a razor and follow with fine grit sand paper. Keep the case bores stuffed good with towels. And make sure you get all the gasket off (all around studs) or you will have sealing issues.
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Old 11th August 2010
BCP's Avatar
BCP BCP is offline
Thanks,
The stock gaskets are thicker than the paper gaskets the dealer gave me. Why the different thickness? And does it make a difference with anything (compression?)?
Shu's Avatar
Shu Shu is offline
Originally Posted by BCP View Post
Thanks,
Mine came stock with the paper base gaskets but that was back in 2000. Any time you change the thickness of the base gasket you change the squish area and compression. Do you have any idea what the difference in thickness is between the two gaskets? Whatever that is is how much squish would be reduced. Then you could calculate the corrected compression ratio. I doubt on a stock application it would affect either enough to make a difference.
Bike Builder
I've tried the spray on stuff, doesn't work on well on base gaskets. I had to do multiple applications and I still scratched the hell out of the surface too. Not enough to leak, but it's scratched. Didn't leak anyway.
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
take a copper tube (brakeline sized) and hammer one end flat, then file down a bevel on the flattened side nice and sharp. it won't stay sharp but you keep dressing it as needed.
you can wrap the other end with tape to protect your palm while using your new gasket scraper, and the copper is soft enuff to not damage the case.
"lord of the Night Lite"
thank god for darwin ;)
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
I use razor blades and then kerosene to clean it. Takes patience.
John Wayne - "The Shootist"
Old 18th May 2015
BlackBikeDave's Avatar
BlackBikeDave BlackBikeDave is offline
BlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud of
this is a way old thread but I just wanted to add that of all the work I have done so far on the top end...base gasket removal is the worst part of the entire project.....gasket remover from the carzone store softened it up a little but you have to continually apply it and let it sit...scrape, then more gasket remover and repeat and repeat and repeat!!! Totally SUCKS!!! but after 2 days and hours of time..I am almost done
Jerome 'Kid' Campo - 2/27/13 RIP "and I Ride like the Wind..To Be Free Again"
