Last Post: sifty
0 Vm38 o ring
Last Post: conkey
0 1974 XLH Rebuild
Last Post: ericfreeman
0 an interesting vintage XLCH review...
Last Post: joe s
5 Stock 1982 XLS Gas Tank Mounts
Last Post: MxYoung954
0 Horseshoe Oil tanks repo China?
0 1977 sporty
Last Post: 1Scooter
0 oil line routing-a thought
0 1959 xlh
Last Post: thomastoth
0 Tank Art
Last Post: joe s
0 Lost for words.
0 DO NOT use GMAIL.COM email for XLFORUM.NET
0 Rip jim preisler
0 TC88A and higher compression timing
Last Post: techson
14 What made the best Improvement to your Sporty??
Last Post: wardie
0 DOT 5 Flush/Bleed Routinely?
Last Post: hbsporty
0 BSA A10 bobber…
0 Cam question...
0 Chain Lube
0 I have a couple questions regarding a 2004 883 Custom
Last Post: Andy56
0 What engine oil do you use?
0 What jets do you use?
Last Post: gearbanger
Jon2R, Pink (68), blackcloud (61), harleyguy2064 (58), JamieBee (49), csmith836 (47)
View Poll Results: what do you run
stock 278 16.72%
stock with punched out mufflers 142 8.54%
slip ons with baffles 417 25.08%
slip ons without baffles 117 7.04%
aftermarket with baffles 376 22.61%
aftermarket without baffles 299 17.98%
stock with gronk mod baffles 34 2.04%
Voters: 1663. You may not vote on this poll
  #411
Old 12th June 2019
Sportster/Buell Model: 1200
Wide open
Old 16th July 2019
a-sad-anorak's Avatar
a-sad-anorak a-sad-anorak is offline
Sportster/Buell Model #2: Superlow Sportster
Sportster/Buell Year #2: 2013
a-sad-anorak has a reputation beyond reputea-sad-anorak has a reputation beyond reputea-sad-anorak has a reputation beyond reputea-sad-anorak has a reputation beyond reputea-sad-anorak has a reputation beyond reputea-sad-anorak has a reputation beyond reputea-sad-anorak has a reputation beyond reputea-sad-anorak has a reputation beyond reputea-sad-anorak has a reputation beyond reputea-sad-anorak has a reputation beyond reputea-sad-anorak has a reputation beyond repute
The bike came with drag pipes with no baffles. Although it sounded great, it also attracted attention from neighbours in about half a mile radius. I bought a couple of slipons similar to the originals but 3 inches shorter. I also bought a couple of 4" baffles to go in the pipes before the silencer. These proved to be unnecessary. The silencers are 2 1/4 inches whilst the drag pipes were 1 3/4 inches. I found that the standard hanger(bracket) had 1/4 spacers between it and the frame. By removing these spacers the silencers were aligned with the pipes and also sat nicely against the bike. The exhaust note is now reduced and I have happy neighbours. In a way it didn't matter anyway as they only speak French and I only speak English. However, they no longer put their hands over their ears when I start her I must admit I miss the drag pipes.
Old 9th September 2019
Clevspeed Clevspeed is offline
Sportster/Buell Model: 1200 Sportster 48
Clevspeed is just really niceClevspeed is just really niceClevspeed is just really niceClevspeed is just really niceClevspeed is just really niceClevspeed is just really niceClevspeed is just really niceClevspeed is just really niceClevspeed is just really niceClevspeed is just really niceClevspeed is just really nice
Nice looking Ironhead you have there!
Old 30th June 2022
Graywolf Graywolf is offline
Glass packs with rudimentary set of simple baffles.
GW
What I need is some minions.
Old 30th June 2022
84rzv500r 84rzv500r is offline
Sportster/Buell Model: XL 1200 S....X
Sportster/Buell Model #2: XR-1000 RX
Sportster/Buell Year #2: 83
Other Motorcycle Model: SOLD - RZV500R/R1 hybrid
Other Motorcycle Year: 1984
84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute
XL1200S gets a Cone Engineering 2:1 off the shelf.... XR1000 gets a homebrew factory Megs with no baffles and supertrap cans tigged on running 12 plates and open endcaps...
1999 XL 1200 Sport RX, SE 7500 ignition, SE air filter, DynoJet, K&N, Cone Engineering 2:1 pipe, Storz Steering damper, with 2012 XR1200X perf forks, 3.5 x18" wheels front and rear, Galfer stainless lines, XR1200 4 piston front calipers, 18" Dunlop D404 130/70 and Dunlop trailmax mission 140/80-18 rear XR1200X perf shocks, 19/48 530 chain conversion, Dart Flyscreen, Antigravity LiFePO4 battery
Old 8th July 2022
handa700 handa700 is offline
Sportster/Buell Model: 1200 Roadster
handa700 is an unknown quantity at this point
Default Khromewerks slip-ons
3" Khromewerks slash-cut slip-ons. Drag Specialties 3" baffle. stock head pipes with heat shields. With the re-jet and S & S stealth air cleaner it's loud enough and runs very cool.
Old 9th July 2022
Stray Cat Stray Cat is offline
Stray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of light
Stealth Pipe Bomb Exhaust 2-1
Old 30th October 2022
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
I run open drags-my hearing is shot anyway and it helps just a little ruining people's concentration texting.
I also get the mid-range flats
My '03 has supertrapp do-alls, I want to go to 20 discs soon as I weld up the inside brkt on one of the pipes
Steve
'01 Cyclone stock
'13 FXDC 96" stock
