Last Post: Randy_rots
0 Top end failure
0 Coil readings
Last Post: Billy1200
0 Bandanas
Last Post: Padre
0 Top end reassembly...what goes where!?!?!
5 Eye Protection When Riding?
0 3/4” Axle Drum Brake ??
0 UltraCool oil cooler safety concern
0 New guy from IL
8 Inexplicable miss
Last Post: gwcrim
0 Info needed on mini sumps.
14 I just kind of stumbled in here... like 100 times.
0 Chinese S&S carbs
Last Post: 01rk
0 Inherited Ironhead
0 XR mutt race bike progress
Last Post: Akdawg
0 Noise and rod play
Last Post: Vic8028
0 Transmission issues
Last Post: bobber58
0 Ironhead high speed cruise prob
Last Post: BigLerowski
0 K/n air filter,, and s/s super b long thumb screw bolts
Last Post: xElvis
0 Cleaning carbon build-up
Last Post: xElvis
FORCE50 (68), marcus (55), gardkarlsen (50), dhoppe1 (42), Hagen (42), tdyer55 (38)
Here's the Sportsterpedia page on Sensors - Including the CKP - It is very important:
http://sportsterpedia.com/doku.php/t...shaft_position
And here's the page on Ignition Modules & Coils:
http://sportsterpedia.com/doku.php/t...k:evo:engctl01
The Coil can cause the same issue from heat. I would certainly try the hair dryer test on the coil.
But it is concerning that the ICM fails with heat. They are usually decent quality (except the nosecone versions in high heat) and we only look to replace them as a last resort, but they do fail.
Heat can sometimes cause connection failures - so do check the CKP connector as Paul mentioned but also the connections of the ICM itself. Pull off the ICM connector & make sure each pin is fully seated and not backing out of place when pressed onto the ICM.
Just as a regular maintenance action, you should always check & tighten your battery connections & your Powertrain Ground:
When you're having issues with the electrical system, use this Sportsterpedia section about checking the battery cables, voltages and grounds:
tamaro tamaro is offline
Sportster/Buell Model: 883
tamaro is an unknown quantity at this point
Thanks for the wealth of information!
I cleaned and reattached the crank position sensor terminals and cannot recreate any of the symptoms with the “blowdryer” test on either the coils, ICM, or the sensor.
However, I still managed to shut down in a half mile after warming up the bike (couldn’t keep up going into 3rd gear, shifted down, and broke down). Once cooled off, it started up like a champ.
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Year: 1974
Time to check for DTC's.
If it fails consistently enough, you can use Cold Spray to test in reverse - wait until it fails -
spray the coil - test to see if it fires up
if not, spray the CKP sensor - test to see if it fire up
if not, spray the ICM - test to see if it fires up
Since the bike restarts after cooling down, using the Cold Spray should allow you to determine exactly what device needs to cool down before it works again.
LLOYD883's Avatar
LLOYD883 LLOYD883 is offline
Sportster/Buell Model: xl883c
LLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant future
Originally Posted by tamaro View Post
Thanks I’ll definitely check the crank position sensor! Shouldn’t I get a diagnostic trouble code if the sensor is faulty though?
To my surprise, the only codes I got were that my Turn signals were disconnected.
It doesn't always throw a code, it's usually intermittent. One of the main symptoms of a bad sensor is trouble idling when hot.
2005 883XLC - 42 slow jet, 2 1/2 turns out - N65A needle shimmed 0.030" with stock 170 main jet - 07 1200 W cams - mildly ported stock heads - Arlen Ness Big Sucker air cleaner with HD round nostalgia cover - Khrome Werks 3" tapered slip-ons - SE 1200 ignition module - microTach - Mustang "solo tripper" seat - 12 1/2" Progressive 412 chrome rear shocks.
I installed a new sensor... still shut down after warming up for 4min and had trouble turning back on.
However, cooling the ignition coil or ignition control module with compressed keyboard cleaner didn’t work either. Not sure if there’s another “cold spray” I’m supposed to use for that test, or if I have to give in and turn the bikenover to a mechanic.
I was referring to something like this:
(Click the Image for linking to Amazon.com)
Maybe you can find something equivalent at your auto parts store -
When it fails, did you actually test to see if you're getting spark?
Did you do a manual spark test, triggering the coils manually?
http://sportsterpedia.com/doku.php/t..._testing_spark
LLOYD883's Avatar
4 minutes doesn't seem enough time for anything but the heads to warm up. Have you checked the spark plugs and/or ignition leads ?
The spark plugs seemed alright, spaced and installed them <9,000 miles ago. And now apparently my 6mo old Harley battery isn’t holding charge.
Testing the voltage seemed to indicate that the stator and regulator/rectifier were functioning, so I’m at a loss �� I’ll be buying some freeze spray as per the recommendations above and also re-inspecting the leads/spark plugs
